电子发烧友论坛|
你好,我们对射频连接有一个直流放电路径要求,我们需要有一个直流接地路径,以达到ESD的原因,这可以通过附加一个特殊的0dB衰减器来完成。
但是,如果测试仪器已经内部接地,则不需要这种特殊的衰减器。 我的问题是PNA和PNA-X是否需要将这种特殊衰减器添加到RF连接中。 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello, We have a DC bleed path requirement for RF connections, where we need to have a DC path to ground for ESD reasons, which can be accomplished by attaching a special 0dB attenuator with that provision. However, if the test instrument is already internally grounded, then there is no need for this special attenuator. My question is whether the PNA and PNA-X's would require this special attenuator to be added to the RF connections or not. Thanks, rok |
1个回答
我认为接近0dB的衰减器可以工作(我们建议将其用于天线和非常长的电缆),但是如果你只需要一些直流接地路径,你可以将一些类型的负载放在后面的直流偏置BNC连接器上。
PNA ...假设您当然安装了偏置T恤! 无论你使用什么负载(或短路),电阻都是一欧姆或两欧姆。当然,为了获得最佳的ESD保护,最好将它连接到设备(长电缆或天线或其他)*之前*连接到它 PNA避免任何大电压尖峰通过PNA的内部放电。编辑:jvall于2013年3月15日下午1:26 以上来自于谷歌翻译 以下为原文 I would think a near 0dB attenuator would work (and we recommend this for antennas and very long cables), but if you just need some DC path to ground you could put a load of some type on the DC bias BNC connector on the rear of the PNA...assuming you have bias tees installed of course! The resistance will be an ohm or two plus whatever load you use (or a short.) Of course for best ESD protection, it is better to connect it to the device (long cable or antenna or whatever) *before* you connect it to the PNA to avoid having any large voltage spikes being discharged through the guts of the PNA. Edited by: jvall on Mar 15, 2013 1:26 PM |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 00:41 , Processed in 0.678387 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2865
