电子发烧友论坛|
大家好,
我正在使用STM8L001J3设计一个简单的遥控器。 为了生成一个独特的24位S / N,我将使用微处理器的96位(12字节),可从0x4925地址读取。 有人已经尝试过某种方法或计算算法吗? 以上来自于谷歌翻译 以下为原文 Hello to everyone, I'm designing a simple remote control using STM8L001J3. To generate a unique 24bit S/N, I would to use the 96bits (12bytes) of the micro, readable from 0x4925 address. There is someone who has already experimented with some method, or algorithm for the calculation? |
8个回答
你好Sisto,
这个话题在这个论坛上已经讨论过了。你可以参考这两个主题: https://community.st.com/0D50X00009XkXB0SAN https://community.st.com/community/stm8-community/stm8-mcus/blog/2017/12/09/stm8l001j3-low-power-stm8-mcu-in-8-pin-so-8-package 在第二个线程唯一ID中 讨论了STM8L001J3,所以在你提到的设备中。 问候 Szymon 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello Sisto, This topic was already discussed a bit on this forum. You can refer to these two threads:
STM8L001J3 is discussed, so in device, which you mentioned. Regards Szymon Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
大家好,
我道歉,但是,也许,我没有很好地解释。 问题不是读取UNIQUE ID(参见简单的asm列表),而是使用它来计算唯一的24位序列号以识别遥控器。 这样我就不需要使用滚动码芯片或DIP开关。 我基本上必须使用96位UNIQUE ID来获得唯一的24位数字。 ... TINY uint8_t UNIQUE_ID_BUF [12]; ... //读取STM8L001J3 MCU UNIQUE_ID #pragma asm ldw x,#11 L1:ld a,($ 4925,x) ld(_UNIQUE_ID_BUF,x),a decw x jrsge L1 #pragma endasm 以上来自于谷歌翻译 以下为原文 Hello to all, I apologize, but, perhaps, I have not well explained. The question is not to read UNIQUE ID (see simple asm listing), but use it to calculate a unique 24bit serial number to identifiy the remote control. In this way I do not need to use rolling code chips or dip switches. I basically have to use 96-bit UNIQUE ID to get a unique 24-bit number. ... TINY uint8_t UNIQUE_ID_BUF[12]; ... // Read STM8L001J3 MCU UNIQUE_ID #pragma asm ldw x,#11 L1: ld a,($4925,x) ld (_UNIQUE_ID_BUF,x),a decw x jrsge L1 #pragma endasm |
使用散列函数计算24位代码。它不能保证是唯一的,但与从可用的96中提取24个任意位相比,不太可能发生冲突。
以上来自于谷歌翻译 以下为原文 Use a hashing function to compute a 24-bits code. It isn't guaranteed to be unique, but is less likely to have collisions than extracting 24 arbitrary bits from the 96 available. |
但用它来计算一个独特的24位序列号来识别遥控器。 1)简单地从uid中选取24位数据;要么 2)在uid上使用哈希函数。喜欢crc 24。 以上来自于谷歌翻译 以下为原文 ' but use it to calculate a unique 24bit serial number to identifiy the remote control.' 1) simply pick 24 bits of data from the uid; or 2) use a hash function on the uid. like crc24. |
最后,这是我简单,经过测试的最终解决方案:
/ * 使用STM8L001J3,96位 UNIQUE_ID,为遥控器计算唯一的24位序列号: 输入:UNIQUE_ID [] = 12字节Micro ID缓冲区 输出:SERIAL_NUM =唯一的24位远程序列号 TELE_FRAME_BUF [] =编译要传输的遥控帧的前三个字段 * / 空虚 CALC_SERIAL_NUM(无效 ) { uint8_t inx; uint32_t Serial_1,Serial_2; // Leggi MCU UNIQUE_ID #pragma asm ldw x,#11 L1: ld a,(4925美元 ,X) ld(_UNIQUE_ID_BUF,x),a decw x jrsge L1 #pragma endasm // ----------------------- 对于 (INX = 0 ; INX&LT; 4 ; INX ++) { Serial_1 + = UNIQUE_ID_BUF [inx]; Serial_1&lt;&lt; = 8 ; } 对于 (INX = 4 ; INX&LT; 8 ; INX ++) { Serial_2 + = UNIQUE_ID_BUF [inx]; Serial_2&lt;&lt; = 8 ; } Serial_1 + = Serial_2; 对于 (INX = 8 ; INX&LT; 12 ; INX ++) { Serial_1 + = UNIQUE_ID_BUF [inx]; } // -------------------------------------- SERIAL_NUM = Serial_1; Serial_1&gt;&gt; = 24 ; SERIAL_NUM&amp; = 0xFFFFFF ; SERIAL_NUM + = Serial_1; TELE_FRAME_BUF [0 ] =(uint8_t)((SERIAL_NUM&amp; 0xFF0000 )&gt;&gt; 16 ); TELE_FRAME_BUF [1 ] =(uint8_t)((SERIAL_NUM&amp; 0x00FF00 )&gt;&gt; 8 ); TELE_FRAME_BUF [2 ] =(uint8_t)(SERIAL_NUM&amp; 0x0000FF ); } 以上来自于谷歌翻译 以下为原文 At last, this is my simple, tested, final solution: /* Using the STM8L001J3, 96bit UNIQUE_ID, calculate a unique 24 bit serial number for the remote control: Input : UNIQUE_ID[] = 12 bytes Micro ID Buffer Output : SERIAL_NUM = Unique 24 bit of remote serial number TELE_FRAME_BUF[] = Compile the first three fields of remote control frame to transmit */ void CALC_SERIAL_NUM(void ) { uint8_t inx; uint32_t Serial_1,Serial_2; // Leggi MCU UNIQUE_ID #pragma asm ldw x,#11 L1: ld a,($4925 ,x) ld (_UNIQUE_ID_BUF,x),a decw x jrsge L1 #pragma endasm //----------------------- for (inx=0 ; inx<4 ; inx++) { Serial_1 += UNIQUE_ID_BUF[inx]; Serial_1 <<=8 ; } for (inx=4 ; inx<8 ; inx++) { Serial_2 += UNIQUE_ID_BUF[inx]; Serial_2 <<=8 ; } Serial_1 += Serial_2; for (inx=8 ; inx<12 ; inx++) { Serial_1 += UNIQUE_ID_BUF[inx]; } //-------------------------------------- SERIAL_NUM = Serial_1; Serial_1 >>= 24 ; SERIAL_NUM &= 0xFFFFFF ; SERIAL_NUM += Serial_1; TELE_FRAME_BUF[0 ] = (uint8_t) ((SERIAL_NUM &0xFF0000 ) >> 16 ); TELE_FRAME_BUF[1 ] = (uint8_t) ((SERIAL_NUM &0x00FF00 ) >> 8 ); TELE_FRAME_BUF[2 ] = (uint8_t) (SERIAL_NUM &0x0000FF ); } |
uint32_t Crc24Quick(uint32_t Crc,size_t Size,uint8_t * Buffer)
{ static const uint32_t crctab [] = { 0x00000000,0x01864CFB,0x038AD50D,0x020C99F6,0x0793E6E1,0x0615AA1A,0x041933EC,0x059F7F17, 0x0FA18139,0x0E27CDC2,0x0C2B5434,0x0DAD18CF,0x083267D8,0x09B42B23,0x0BB8B2D5,0x0A3EFE2E};而(Size--) { Crc ^ =(uint32_t)* Buffer ++&lt;&lt; 16; Crc =(Crc 20)&amp;为0x0F]; Crc =(Crc 20)&amp;为0x0F]; } return(Crc&amp; 0xFFFFFF); } 以上来自于谷歌翻译 以下为原文 uint32_t Crc24Quick(uint32_t Crc, size_t Size, uint8_t *Buffer) { static const uint32_t crctab[] = { 0x00000000,0x01864CFB,0x038AD50D,0x020C99F6,0x0793E6E1,0x0615AA1A,0x041933EC,0x059F7F17, 0x0FA18139,0x0E27CDC2,0x0C2B5434,0x0DAD18CF,0x083267D8,0x09B42B23,0x0BB8B2D5,0x0A3EFE2E }; while(Size--) { Crc ^= (uint32_t)*Buffer++ << 16; Crc = (Crc << 4) ^ crctab[(Crc >> 20) & 0x0F]; Crc = (Crc << 4) ^ crctab[(Crc >> 20) & 0x0F]; } return(Crc & 0xFFFFFF); } |
最后,这是我简单,经过测试的最终解决方案:' 没有乐趣,如果我们不能重新发明轮子, 以上来自于谷歌翻译 以下为原文 ' At last, this is my simple, tested, final solution:' no fun if we cannot re-invent the wheels, |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 00:22 , Processed in 0.849539 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3173
