电子发烧友论坛|
下午好,
我试图确定用lsm6ds3加速度计计算的角度的理论精度。根据规格,我看到有许多不准确/噪音的来源。噪声密度由范围和采样频率决定,由温度和零点精度引起的零点变化。其中,零点精度被列为+/- 40mg的常数值。没有提及可用于更好地改变该值的任何因素(例如,降低范围会降低噪声密度)。 当我们确定角度时,我们使用两个读数的arctan。对于45度最坏情况,这意味着我们将得到x = 0.707g和y = 0.707g的理论测量值。如果我假设最差情况零点精度仅在这两个值(+/- 40mg),一个正值和一个负值,我得到x = 0.747和y = 0.667。这给了我一个41.76度的计算角度,这是-3.24度的误差。对于我的申请,这是不可接受的。 我是否正确地假设我们可以在生产后校准零件的零点精度?我们能够准确地获得毫克的零值吗? 在此先感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Good afternoon, I am trying to determine the theoretical accuracy of an angle calculated with the lsm6ds3 accelerometer. From the spec I see there are a number of sources of inaccuracy/noise. There is noise density that is dictated by range and sampling frequency, zero point change due to temperature and zero point accuracy. Of these, zero point accuracy is listed as a constant value of +/- 40mg. There is no mention of any factors that can be used to change this value for the better (e.g. lowering the range reduces the noise density). When we determine the angle we use the arctan of two of the readings. For the 45-degree worst case that means we would get a theoretical measurement of x = 0.707g and y = 0.707g. If I assume worst case zero point accuracy only on both of these values (+/- 40mg), one positive and one negative, I get x = 0.747 and y = 0.667. That gives me a calculated angle of 41.76 degrees which is an error of -3.24 degrees. For my application this is unacceptable. Am I correct to assume that we can calibrate the zero point accuracy out of the part after production? How accurate should we be able to get the zero value in mg? Thanks in advance for your help. |
1个回答
你好格伦,
加速度计每个轴的偏移量为零,会影响倾斜的精度。零偏移的典型值约为40毫克。我们有校准库可以消除零偏移( http://www.st.com/en/embedded-software/osxmotionac.html )或者您可以手动校正偏移或进行球体拟合。 以上来自于谷歌翻译 以下为原文 Hello Glen, Accelerometer will have zero offset about each axis and will influence the accuracy of tilt. Typical value of zero offset is around 40 mg. We have calibration library available to remove zero offset ( http://www.st.com/en/embedded-software/osxmotionac.html ) or you can correct the offset manually or doing sphere fit. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 06:39 , Processed in 0.581962 second(s), Total 71, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1957
