电子发烧友论坛|
您好,我之前发布的是为了确保我有合适的线缆,看起来就像我一样。
所以也许有人可以帮我这个: 当我启动冲击(独立或从项目导航器中)并运行自动电缆检测时,它无法看到任何电缆。 在我的设置中,xilinx卡通过USB电缆连接到计算机上的USB端口,xilinx卡还包含一个USB端口。 该卡属于Spartan 3E入门套件。 入门套件附带ISE 9.2i和EDK 9.2i(我2年前买了这个套件)。 当我购买了套件我成功安装了ISE并设法将一个项目下载到卡上,证明它当时正常工作。 我试图在4个操作系统上进行设置 - Debian(当前),Gentoo(当前),Windows 7和Windows Vista。 在linux系统上影响抛出了错误的windrvr6错误。 我对此进行了广泛的研究,并发现内核2.4.x(当前2年前)内置的u***并行编程支持后来停止了,并且出现了一个名为Jungo的项目,它提供了这些驱动程序。 我可以找到在线参考的这个驱动程序的最后成功编译是2.6.16,但我们目前在2.6.37并且驱动程序不再编译。 基于此,我理解为什么影响无法识别设备。 在Windows(上面提到的两个版本)上,ISE和EDK的设置成功完成,包括“安装电缆驱动程序”选项。 但是当我运行自动连接时,影响无法检测到电缆。 经过一些谷歌搜索后,我找到了vista + ise 9.2i设置的ug344线缆驱动程序。 我得到了Xilinx软件版本12.4(包括ISE,EDK和其他一些我没有详细研究过的应用程序),因为它们应该能够更好地支持vista和windows 7的有线驱动程序,但我遇到了 安装完成后完全相同的问题。 请注意,在Windows中,驱动程序确实存在,并且ise在控制台中显示windrvr6已加载但仍无法检测到电缆。 最后,我也尝试以兼容模式运行作为管理员,也没有工作。 任何帮助,将不胜感激。 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I had posted earlier to make sure I have the right cable and it seems like I do. So maybe someone can help me with this: When i start up impact (independently or from within the project navigator) and run the auto cable detect it fails to see any cable. in my setup the xilinx card is connected to a u*** port on my computer via a u*** cable, the xilinx card also contains a u*** port. the card belongs to the Spartan 3E Starter Kit. the starter kit came with ISE 9.2i and EDK 9.2i (i bought this kit 2 years ago). when i had bought the kit i had successfully installed the ISE and managed to download a project onto the card demonstrating that it was working right at the time. i have tried to make the setup on 4 operating systems - Debian (current), Gentoo (current), Windows 7 and Windows Vista. on the linux systems impact throws an error of missing windrvr6. i have looked into this extensively and have found that the u***-parallel programming support which was built into the kernel 2.4.x (current 2 years ago) was later discontinued and a project named Jungo emerged which provided these drivers. the last successful compile of this driver that i can find reference to online is 2.6.16, but we are currently at 2.6.37 and the driver does not compile anymore. based on this i understand why impact fails to identify the device. on windows (both versions mentioned above) the setup is completed successfully for the ISE and the EDK, including the 'Install Cable Drivers' option. but impact fails to detect the cable when i run the autoconnect. after some googling around i found the ug344 cable drivers for vista + ise 9.2i setup. i got of the Xilinx software version 12.4 (including ISE, EDK and a few other applications i havent looked at in detail), as these are supposed to have better support for the cable drivers for vista and windows 7, however i was met with the exact same problem after the installation was complete. note, in windows the drivers do exist and the ise shows in the console that windrvr6 was loaded but still it fails to detect the cable. last, i also tried to run in compatibility mode as admin which also didnt work. Any help would be appreciated. Thank you. |
3个回答
我没有Spartan-3e入门套件,所以我猜...
您必须将USB电缆插入电路板,并且必须打开电路板的电源。 如果您运行的是Windows,则应该会看到一条“警报”消息,表明USB设备已被识别和枚举。 此外,USB设备应显示在Windows硬件管理器中。 你在运行哪个操作系统? 是否有当地Xilinx代表或经销商? 也许您可以将电路板运行到它们上面,看看它们的设置是否被识别。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 I don't have the Spartan-3e Starter Kit, so I'm just guessing... You must plug the USB cable into the board, and the board must be powered on. If you are running Windows, you should see an 'alert' message that the USB device has been recognised and enumerated. Also, the USB device should show up in the Windows hardware manager. Which OS are you running? Is there a local Xilinx rep or distributor? Perhaps you can run the board over to them and see if it is recognised on their setup. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
eteam00写道:
我没有Spartan-3e入门套件,所以我猜... 您必须将USB电缆插入电路板,并且必须打开电路板的电源。 如果您运行的是Windows,则应该会看到一条“警报”消息,表明USB设备已被识别和枚举。 此外,USB设备应显示在Windows硬件管理器中。 你在运行哪个操作系统? 是否有当地Xilinx代表或经销商? 也许您可以将电路板运行到它们上面,看看它们的设置是否被识别。 - 鲍勃埃尔金德 谢谢,所以通过该列表:电缆插入,电路板通电。 运行Windows 7,获取警报消息,然后在我关闭它后立即获得驱动程序安装框(1)我得到(2)。 USB设备在硬件管理器中显示为“未知设备”。 不确定我买的商店会有什么帮助...... 以上来自于谷歌翻译 以下为原文 eteam00 wrote: Thanks, so by that list: Cable plugged in, board powered on. Running Windows 7, get alert message and then the driver installation box (1) right after I close it I get (2). The USB device is shown as "unknown device" in the hardware manager. Not sure the shop I bought it from will be any help ... |
你有一台非Windows 7机器吗?
- 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Do you have a non-windows 7 machine around? -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 05:26 , Processed in 0.691077 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1095
