大家好,我需要帮助我的斯巴达3e。
当我运行“配置设备影响”时,我无法编程我的斯巴达3e入门套件,它会提示进度对话框直到61%,然后是一个警告窗口: 影响2344:平台电缆USB固件已更新。 请断开连接,然后将电缆重新连接到USB端口,然后按“确定”完成更新过程。 我重新连接电缆然后按OK,然后按另一个警告窗口: 警告:影响:923:找不到电缆,检查电缆设置。 如果有人知道如何纠正这个错误让我知道,我有Windows Vista家庭高级32位。 以上来自于谷歌翻译 以下为原文 hi all, i need help with my spartan 3e. I cant program my spartan 3e starter kit when i run the "configure device impact" it prompts a progress dialog till 61% and then a warning window: impact 2344:The platform cable USB firmware has been updated. Please disconnect, then reconnect the cable to the USB port, and press ok to complete the update procedure. I reconect the cable and press OK but then another warning window: warning: impact :923:Can not find cable, check cable setup. Please if anyone knows how to correct this error let me know, i have windows Vista home premium 32 bits. |
4个回答
你好,
你能检查任何带有支持操作系统的电缆的PC吗? http://www.xilinx.com/ise/ossupport/index.htm 问候。 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 Hello, Can you check on any PC with the cable which has a supported OS ? http://www.xilinx.com/ise/ossupport/index.htm Regards. ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
好吧我认为问题是操作系统,所以我再次改为XP专业版,一切顺利,谢谢......
以上来自于谷歌翻译 以下为原文 well i thought the problem was OS , so i have changed to XP professional again and everything goes ok thanks... |
你好,
感谢更新。 很高兴您切换到支持操作系统。 问候, 下摆。 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 Hello, Thanks for the update. Glad that you switched to a supporting OS. Regards, Hem. ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,我有我的Windows Vista家庭高级32位和Spartan 3E同样的问题...但我不能改变操作系统
有一些方法可以纠正这个错误 谢谢 以上来自于谷歌翻译 以下为原文 hi, i have the same problem with my Windows Vista Home premium 32 bits and Spartan 3E...but i can't to change the OS there is some way to correct this error thanks |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 00:38 , Processed in 0.628185 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2084
