电子发烧友论坛|
我刚买了一个Digilent spartan 3e启动板。我把它插入我的笔记本电脑并检测到它但是它说安装你的硬件错误甚至ISE影响说没有电缆连接..我该怎么办?消息由blakaxe编辑于09-
04-2007 10:54 PM 以上来自于谷歌翻译 以下为原文 I just got a Digilent spartan 3e starter board. I plug it in to my laptop and it detects it but it says error in installing your hardware and even ISE impact says no cable connection.. What do i do? Message Edited by blakaxe on 09-04-2007 10:54 PM |
17个回答
ISE版本?操作系统版本?您也可以在另一台计算机上试用您的主板。
以上来自于谷歌翻译 以下为原文 ISE version?OS version? You can also try your board in another computer. |
尝试使用FAQ中的分辨率23强制进行固件更新:http://www.xilinx.com/xlnx/xil_ans_display.jsp?iLanguageID=1&getPagePath=20429您可以设置一个环境变量来强制iMPACT更新电路板固件
, - 保罗 以上来自于谷歌翻译 以下为原文 Try forcing a firmware update using resolution 23 in the FAQ: http://www.xilinx.com/xlnx/xil_ans_display.jsp?iLanguageID=1&getPagePath=20429 There is an environment variable you can set to force iMPACT to update the board firmware, -Paul |
我强制进行固件更新..它做了一些更新然后它仍然说连接失败甚至窗口说找到了新的硬件:platforn u*** cable“和”XILINX“但是它说硬件安装过程中出现了问题,你的设备可能无法正常工作。
.ISE iMPACT表示没有找到电缆。请帮助我使用登录我的项目尝试使用常见问题解答中的第23号分辨率强制进行固件更新:http://www.xilinx.com/xlnx/xil_ans_display.jsp?iLanguageID = 1& getPagePath = 20429您可以设置一个环境变量来强制iMPACT更新电路板固件,-Paul 以上来自于谷歌翻译 以下为原文 i forced a firmware update.. it does some update and then it still says connection failed Even windows says found new hardware :platforn u*** cable" and "XILINX" But then it says a problem occured during hardware installation and your device might not work properly.. ISE iMPACT says cable not found.. please help i need to use to board for my project Try forcing a firmware update using resolution 23 in the FAQ: http://www.xilinx.com/xlnx/xil_ans_display.jsp?iLanguageID=1&getPagePath=20429 There is an environment variable you can set to force iMPACT to update the board firmware, -Paul |
每次我打开电路板窗户都说找到了新的硬件..
以上来自于谷歌翻译 以下为原文 Each time i switch on the board windows says found new hardware.. |
您应该让“发现新硬件”向导运行3次。
这是加载固件所必需的.-保罗 以上来自于谷歌翻译 以下为原文 You shoudl let the "Found New Hardware" wizard run 3 times. This is required to load the firmware. -Paul |
大家好
我是斯巴达3 e技术的新手! 我一直在努力使连接电缆像10小时! 我正在使用Vista !! 我的主板被称为入门套件,它根本没有启动!! 我正在使用Xlinix 10.1,除了警告错误923无法连接电缆,我不会得到任何错误! 我正在使用USB连接,我不应该使用什么类型的连接? 它是并行III /并行IV / mutliPROM还是USB Xlinix? 顺便说一下,它永远不会为USB Xlinix提供选项 有人可以向我解释这个问题吗? 将USB插入笔记本电脑后,它无法读取斯巴达设备 非常感谢 d 以上来自于谷歌翻译 以下为原文 hi all I new to spartan 3 e technology !! I have been trying so hard to make connection cable like for 10 hours !! I am using Vista !! My board is called starter kit which did not start at all!! I am using Xlinix 10.1 and I donot get any errors apart from a warning saying error 923 Cannot connect cable!! I am using USB connection and I donot what type of connection should I use ? Is it parallel III / parallel IV / mutliPROM or USB Xlinix ? and by the way it never gives the option for USB Xlinix Can somebody explain the problem to me ? It fails to read the spartan device once I plug the USB into my laptop thanks a lot d |
嗨,你的主板的品牌是什么?,Nexys of Digilent?,我对这个主板有类似的问题。
以上来自于谷歌翻译 以下为原文 Hi, What is the brand of your board?, Nexys of Digilent?, I had a similar problem with this board. |
是的,digilent Spartan 3 E(FG320)出现问题
但我已经安装了驱动程序,USB正在工作! 但是我的引脚配置有问题! 我们如何制作引脚配置文件? 另外一个问题是,如果pin文件已经由不同类型的板组成,我们是否可以将网表位置更改为我们正在使用的板并运行它! 我试图改变现有的pin文件来运行LED和clk和btn功能,但它没有用!! 非常感谢老兄! 以上来自于谷歌翻译 以下为原文 yes there was a problem with digilent Spartan 3 E ( FG320 ) but i have installed the drivers and USB is working !! However i have problem with the pin configuration ! How do we make a pin configuration file ? And also another question would be if pin file is already made of different type of board, could we change the net list location to the board that we are using and run it !! I tried to change the existing pin file to run the LED and clk and btn functions and it did not work !! thanks a lot dude !! |
您好,您必须安装digilent adept软件,这是链接:
http://www.digilentinc.com/Software/Adept.cfm?Nav1=Software&Nav2=Adept 再见! 以上来自于谷歌翻译 以下为原文 Hello, you must install digilent adept software, this is the link: http://www.digilentinc.com/Software/Adept.cfm?Nav1=Software&Nav2=Adept BYe! |
嗨斯巴达用户
我有一个Spartan 3E入门套件和ISE Webpack 10.1。 我的操作系统是华硕笔记本电脑上的Vista Home Premium。 我已经使用USB线将我的Spartan连接到笔记本电脑,在ISE iMPACT中我得到了消息:没有电缆。 当我将它连接到我的笔记本时,我发出了一条消息:新设备已被连接。 让Windows自动查找并安装驱动程序。 但后来它说找不到司机。 我在互联网上读到了这一点,我发现在ISE Webpack安装过程中,有一个选项可以选择u*** cable驱动程序。 我记得我没有标记任何东西,但我也不记得有关标记u***驱动程序的问题。 我还读到我需要安装特殊的USB驱动程序,所以我已经下载了。 它们被命名为“install_xu*** / install_xu***.bat”。 但是当我点击.bat文件时,我有一条消息说:“错误:无法打开服务控制管理器。确保以管理员权限运行。错误:初始化驱动程序失败。” 顺便说一句,我的个人资料是管理员资料。 同样在ISE iMPACT中我有一条消息“没有检测到电缆。去完成安装驱动程序。” 我怎么能解决我的问题??? 我该怎么办? 如何让ISE iMPACT下载文件给我的Spartan? 对任何有助于解决方案的解决方案来说真是太大了 以上来自于谷歌翻译 以下为原文 Hi Spartan Users I have a Spartan 3E Starter Kit and ISE Webpack 10.1. My OS is Vista Home Premium on Asus notebook. I have connected my Spartan to notebook with a USB cable and in ISE iMPACT i got message: no cable. When i connect it to my notebook i gave a message: New device is conencted. Let Windows find and install drivers automatically. But then it says no drivers found. I read in internet about that and I found that during ISE Webpack installation there is an option with drivers for u*** cable. I remember that i didn't unmark anything but also I don't remember that question about mark u*** drivers. I also read that i need to install special USB drivers so i have downloaded. They are named "install_xu***/install_xu***.bat". But when i click that .bat file i have a message saying: "Error: Cannot open service control manager. Make sure you are running with Administrator privileges. Error: Initializing driver failed." And by the way my profile is an Administrator profile. Also in ISE iMPACT i have a message "no cable detected. Go and finish installing drivers." How could i solve my problem??? What should i do? How to make ISE iMPACT downloading files to my Spartan? Really big thx for any solutions which will help :) |
您好,这是您的FPGA板的品牌,Digilent?,您必须使用digilent adept软件证明,我希望您的回复,再见!
链接:http://digilentinc.com/Software/Adept.cfm?Nav1 = Software& Nat2 = Adept :) 以上来自于谷歌翻译 以下为原文 Hello, which is the brand of your FPGA board, Digilent?, You must prove with digilent adept software, I hope your reply, bye! link: http://digilentinc.com/Software/Adept.cfm?Nav1=Software&Nav2=Adept :) |
我有FPGA Xilinx Spartan 3E,这个勤奋的专业SDK是什么,它可能不适用于我的FPGA
以上来自于谷歌翻译 以下为原文 I have FPGA Xilinx Spartan 3E, what is this diligent adept SDK, it's probably not for my FPGA |
使用Digilent的Adept软件,您将对Spartan 3 FPGA进行编程,我使用该软件,我的Spartan 3运行良好,再见!
链接:http://digilentinc.com/Software/Adept.cfm?Nav1 = Software& Nat2 = Adept 再见:) 以上来自于谷歌翻译 以下为原文 With Adept Software of Digilent ,you will program your Spartan 3 FPGA, I have use this software and my Spartan 3 operate well, bye!! LINK : http://digilentinc.com/Software/Adept.cfm?Nav1=Software&Nav2=Adept BYE :) |
我使用Win Xp Professional在我的电脑上安装Webpack ISE 10.1,一切都很好。
但我仍然想在WIn Vista Home Premium的笔记本电脑上工作。 我转到真正的管理员配置文件(这个隐藏的帐户)并安装xu***驱动程序,似乎一切正常,但在将Spartan 3E连接到我的笔记本后再次出现问题。 它说:INF文件有问题。 iPMACT再次说没有电缆。 所以我该怎么做? 以上来自于谷歌翻译 以下为原文 I install Webpack ISE 10.1 on my pc with Win Xp Professional and everything works great. But still i would like to work on my notebook with WIn Vista Home Premium. I go to real Administrator profile (this hidden account) and install xu*** drivers, it seemed that everything was ok, but after connecting Spartan 3E to my notebook there was again a problem. It says: there is a problem with INF file. And iPMACT says again no cable. SO what should i do? |
嘿你们...我刚刚得到这个nexys2板....并且没有CD随之而来......我去网站下载....这个Adept SDK ....但链接不起作用
...并说文件无法找到....我已经通过电子邮件发送了它们......但看起来它需要一些时间......如果你们中的任何人可以与我分享这个sdk .. ......它会让我的生活变得更轻松..... 在此先感谢您的帮助.... 问候, Wasif。 以上来自于谷歌翻译 以下为原文 Hey you guys... i just got this nexys2 board.... and no cd came with it.... i went on the website to download.... this Adept SDK.... but the link is not working... and says file can't be found.... I have emailed them about it.. but looks like it is gonna take some time...... if any of you can share this sdk with me..... it'll make my life very easier..... Thanks in advance for help.... Regards, Wasif. |
我有类似的问题。
我在eBay上买了一个sparten 3e入门套件,无法使用ISE 14.7在Windows 8上运行电缆。 尝试了很多东西......早期版本的ISE,兼容模式等。最终,唯一能够正确安装电缆的是在我的Windows XP系统上安装ISE 8.2(最初硬件附带的版本)。 当运行imact时,它更新了驱动程序,USB电缆终于完全正常运行。 之后我也能够在Windows XP上运行ISE 14.7。 在XP兼容模式下,此相同的过程在Windows 8上不起作用。 以上来自于谷歌翻译 以下为原文 I had a similar problem. I bought a sparten 3e starter kit on ebay and could not get the cable to work on Windows 8 with ISE 14.7. Tried many things... earlier versions of ISE, compatibility modes, etc. Ultimately the only thing that finally got the cable to install correctly was to install ISE 8.2 (the version that came with the hardware originally) on my Windows XP system. When running imact it updated the driver and the USB cable was finally fully functional. After that I was also able to run ISE 14.7 on Windows XP as well. This same procedure did not work on Windows 8 in XP compatibilty mode. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 21:59 , Processed in 1.524514 second(s), Total 104, Slave 87 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1798
