电子发烧友论坛|
我有一个问题:
什么是用于切换FPGA并执行操作的最小能量,执行然后关闭/空闲? 查看低成本FPGA或CPLD(用于批量生产) 在这里有经验的人或者我应该看的地方吗? 任何帮助非常感谢谢谢! 以上来自于谷歌翻译 以下为原文 I have a burning question: What is the Min energy used for switching the FPGA on and performing an operations, execute then switch off/ idle? Looking at a low cost FPGA or CPLD (for mass production) Anyone here that has experiences in that or where I should look? Any help greatly appreciated thanks! |
2个回答
显然,取决于操作是什么。
如果操作是“将引脚C12设置为逻辑1”,那么CoolRunner II可能是最低功耗的Xilinx选项。 您不会通过配置浪费电源(因为CRII是基于闪存的),并且您不会浪费静电,因为那里几乎没有任何电路。 如果操作是“识别UQHD视频3000小时内的所有对象”,那么我怀疑最低的总能耗将是最小的Kintex UltraScale +,它可以满足其中所需的处理硬件。 以上来自于谷歌翻译 以下为原文 Depends what the operation is, obviously. If the operation is "set pin C12 to logic 1", then a CoolRunner II is likely to be the lowest power Xilinx option. You don't waste power with configuration (because the CRII is flash-based), and you don't waste static power because there's hardly any circuitry in there. If the operation is "identify all objects in 3000 hours of UQHD video" then I suspect the lowest total energy consumed will be the smallest Kintex UltraScale+ that can fit the required processing hardware in it. |
非常棒,13μA静态电流和125Mhz 50mA x 3.3V,256个宏单元,每单位约20美元
我想知道1个Artix7和210K Logiccells需要多少个coolrunner芯片,每个单元约50美元 XC7A50T具有ICCINTQ + 120 ICCAUXQ + 40 ICCOQ + 40 mA每组ICCBRAMQ + 60 mA~500mW正常工作,处于暂停状态时它消耗多少功率? 在合成方面,我的设计几乎没有触发器 我可以简单地综合和比较抓取并使用Xilinx功耗估算器(XPE)工具我很抱歉我的问题我应该看看DC和AC开关特性数据表,然后合成然后使用XPE。 无论如何,我都感谢你的帮助 以上来自于谷歌翻译 以下为原文 It is really great, 13 μA quiescent current and on 125Mhz 50mA x 3.3V for 256 macrocells and around 20$ per unit I wonder how many coolrunner chips I need for 1 Artix7 and 210K Logiccells and around 50$ per unit the XC7A50T has ICCINTQ + 120 ICCAUXQ + 40 ICCOQ + 40 mA per bank ICCBRAMQ + 60 mA ~ 500mW in nomal operation and when in suspended state how much power does it consume? in term for synthesis my design has hardly no flip flops I can simply synthesise and compare the seize and use the Xilinx Power Estimator (XPE) tools I am sorry for my question I should have just looked at the DC and AC Switching Characteristics Datasheets, then syntesise and then use the XPE. I'm all set thanks for the help anyways |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 18:01 , Processed in 0.523806 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
392
