电子发烧友论坛|
13.x of 89600不再支持将E4440A用作下变频器。
对我来说很糟糕,因为我正在使用它来支持更高频率到我的旧的基于VXI的VSA。 有没有重新启用它的黑客,类似于修改Windows注册表让12.x识别E4406A? 以上来自于谷歌翻译 以下为原文 13.x of 89600 no longer supports using the E4440A as a downconverter. Stinks for me since that's how I'm using it to support higher frequencies into my older VXI based VSA. Is there a hack to re-enable this, similar to modifying the windows registry to let 12.x to recognize the E4406A? |
1个回答
VSA软件中不再支持E4440A + VXI硬件配置作为测量硬件配置。
没有方法可以添加此配置。 可以手动将E4440A配置为外部下变频器。 虽然VSA无法在此配置中控制E4440A,但您可以将VSA配置为根据外部下变频器显示正确的信息。 http://wireless.agilent.com/wireless/helpfiles/89600B/WebHelp/89600_CSH.htm#../Subsystems/gui/content/dlg_input_usercorrection_frequencyconverter.htm 以上来自于谷歌翻译 以下为原文 The E4440A + VXI hardware configuration is no longer supported as a measurement hardware configuration in the VSA software. There is no method to add this configuration. It is possible to manually configure the E4440A as an external downconverter. While the VSA will not control the E4440A in this configuration you can configure the VSA to display the correct information based on the external downconverter. http://wireless.agilent.com/wireless/helpfiles/89600B/WebHelp/89600_CSH.htm#../Subsystems/gui/content/dlg_input_usercorrection_frequencyconverter.htm |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 20:27 , Processed in 0.492841 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1497
