*带有VEE Pro 9.3 *的E4440A NF编程:每个手册的命令不起作用:加载频率列表“:MMEM:NFIG:LOAD:FREQ,”C:FREQ003.LST “”导致“未定义的标题”;
输出NF“:READ:NFIG:ARR:SCAL:DATA:CORR:NFIG?” 导致“查询未终止”或VEE Pro 9.3中的零列表。 还有“:INIT:IMM”,其次是“FETC; NFIG:ARR:SCAL:DATA:CORR:NFIG?” 产生相同的结果。 本周需要帮助,并在一周的培训课程中获得安捷伦支持。 Thx Tomtomjr 以上来自于谷歌翻译 以下为原文 *E4440A NF programming w/VEE Pro 9.3*: commands per manual don't work: To load frequency list ":MMEM:NFIG:LOAD:FREQ, "C:FREQ003.LST"" results in "undefined header"; to output NF ":READ:NFIG:ARR:SCAL:DATA:CORR:NFIG?" results in "query unterminated" or a list of zeroes in VEE Pro 9.3. Also ":INIT:IMM" followed by "FETC;NFIG:ARR:SCAL:DATA:CORR:NFIG?" yields same results. Need help this week and Agilent Support in week long training session. Thx Tomtomjr |
9个回答
内存语句应为“:MMEM:NFIG:LOAD:FREQ, C:FREQ003.LST '”,因为引号内不能有引号。
对于其他错误,你执行了“:INST:SEL:NFIGURE”吗? 我在编程手册中没有看到噪声系数命令。 问候, 以上来自于谷歌翻译 以下为原文 The memory statement should be ":MMEM:NFIG:LOAD:FREQ, 'C:FREQ003.LST'" because you can't have quotes within quotes. For the other errors, have you executed ":INST:SEL:NFIGURE"? I don't see the noise figure commands in my programming manual. Regards, |
emcpete,我尝试使用单引号和双引号以及各种斜杠来解决C:和A:驱动器。
没有任何效果。 我也事先发送了“:INST:SEL:NFIG”。 谢谢你的建议,TomtomJr 以上来自于谷歌翻译 以下为原文 emcpete, I've tried addressing the C: and A: drives with both single and double quotes and with variations of slashes. Nothing worked. Also I did send ":INST:SEL:NFIG" beforehand. Thanks for your suggestions, TomtomJr |
a38001230 发表于 2019-1-10 19:49 附加是指定文件位置的更简单方法。 您需要确保该位置存在该文件。 另外,在你的FETC语句中你使用分号,它应该是冒号: 以上来自于谷歌翻译 以下为原文 Attached is an easier way to specify a file location. You need to make sure that that file exists at the location. Also, in your FETC statement you use a semi-colon, it should be colons : 附件
分号上的OOP。 只是一个错字。 我会试试你的建议。 Thx,TomtomJr 以上来自于谷歌翻译 以下为原文 OOPs on the semicolon. Just a typo. I'll give your suggestion a try. Thx, TomtomJr |
emcpete,不幸的是加载文件不起作用。 我试过“:MMEM:NFIG:LOAD:FREQ,a”= C:FREQ00S3.LST及以下变化:“:MMEM:NFIG:LOAD:FREQ,”C: FREQ003.LST“,C:FREQ003 .LST“,'C:FREQ003.LST','C: FREQ003.LST',”C: FREQ003.LST“和”:MMEM:NFIG:LOAD:FREQ,“+ a,”:MMEM:NFIG: LOAD:FREQ,“C:FREQ003.LST ”“。 此外,我发现在将噪声系数模式切换到频谱分析仪模式并返回噪声系数模式时,“CALIBRATION”会丢失。 这需要重新加载“STATE”文件,该文件很容易手动完成,但没有远程命令功能。 只有远程获得的测量结果来自标记命令仍然需要帮助。 感谢您一直以来的帮助。 TomtomJr 以上来自于谷歌翻译 以下为原文 emcpete, Unfortunately loading file did not work. I tried ":MMEM:NFIG:LOAD:FREQ, a" with a = C:FREQ00S3.LST and following variations: ":MMEM:NFIG:LOAD:FREQ, a" with C:FREQ003.LST, "C:FREQ003.LST", 'C:FREQ003.LST', 'C:FREQ003.LST', "C:FREQ003.LST" AND ":MMEM:NFIG:LOAD:FREQ, "+a, ":MMEM:NFIG:LOAD:FREQ, "C:FREQ003.LST"". Also I found that "CALIBRATION" was lost when switching to Noise Figure mode to Spectrum Analyzer mode and back to Noise Figure mode. This necessitated re-loading the "STATE" file which was easily done manually but with no Remote Command capability. Only measurement results obtained remotely were from the Markers Commands Still need help. Thanks for your help so far. TomtomJr |
a38001230 发表于 2019-1-10 20:27 TomtomJr,不幸的是,我不再需要E4440A来调试问题。 查看噪声系数的编程手册,代码应该如下所示 - “:MMEM:NFIG:LOAD:FREQ”,其中a == C:FREQ003.LST手册在引号内显示一个共同点。 确保该文件位于根目录中,如图所示。 祝你好运。 以上来自于谷歌翻译 以下为原文 TomtomJr, Unfortunately, I no longer have a E4440A to debug the problem. Looking at the programming manual for noise figure, the code should look like this--":MMEM:NFIG:LOAD:FREQ,", a where a== C:FREQ003.LST The manual shows a common inside the quotes. Make sure the file is located in the root directory, as shown. Good luck. |
lisa1 发表于 2019-1-10 20:34 此外,您可能想要查看是否可以从前面板加载频率列表。 您应该能够使用以下命令加载状态:MMEMory:STORe:STATe 1, 以上来自于谷歌翻译 以下为原文 Also, you may want to see if you can load the frequency list from the front panel. You should be able to load the state with :MMEMory:STORe:STATe 1, |
由于为期一周的培训课程,仍无法将文件远程加载到E4440A中,也无法从安捷伦科技支持部门获取任何信息。 但是,我正在使用一种解决方法,我手动加载测试频率,校准并保存所有“用户预设”。 还保存“州”保险。 到目前为止它的效果很好。 再次感谢你的帮助。 TomtomJr 以上来自于谷歌翻译 以下为原文 Still can't remotely load files into the E4440A and no word from Agilent Tech Support due to a week long training session. However, I'm using a workaround in which I load my test frequencies manually, calibrate and save all in "User Preset". Also save the "State" for insurance. So far it works great. Thanks again for your help. TomtomJr |
TomtomJr,您尝试访问的驱动器必须安装到频谱分析仪。
我想你可以在后面板USB连接器上安装一个闪存盘。 以上来自于谷歌翻译 以下为原文 TomtomJr, The drive that you are trying to access has to be mounted to the spectrum analyzer. I think you could attach a flash drive on the rear panel u*** connector. |
只有小组成员才能发言,加入小组>>
2166 浏览 1 评论
1949 浏览 1 评论
1812 浏览 5 评论
2683 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1640 浏览 4 评论
646浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
447浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
536浏览 0评论
2336浏览 0评论
1388浏览 0评论
GMT+8, 2024-8-7 16:24 , Processed in 1.374726 second(s), Total 92, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
