电子发烧友论坛|
我最近买了一台E4440A PSA分析仪,之前的老板购买了分析仪的Option 111 USB升级套件,USB板,USB线以及覆盖板的金属板都装在盒子里然后安装了它们
USB似乎无法正常工作,当我检查时,我无法在选项列表中看到选项111! 启用此功能是否需要代码字或FW升级? 我知道在较新的型号USB是标准的,但这个单位预约那些,我看着框和文书工作,但没有包含任何启用代码的证书! 该单元的序列号是MY45305016,任何帮助将不胜感激 以上来自于谷歌翻译 以下为原文 i recently bought a E4440A PSA Analyzer , the previous owner had purchased a Option 111 USB Upgrade kit for the analyzer, the USB board, a USB Cable as well as a metal plate to cover the board were in a box and i installed them however the USB doesnt seem to work and i cant see option 111 in the option list when i check ! Is there a code word or a FW upgrade needed to enable this ? i know that on newer models USB is standart but this unit pre dates those , i looked in the box and paperwork but there is no certificate that contains any enable code ! The serial# of the unit is MY45305016 , any help would be appreciated |
3个回答
嗨 - 应该使用选件111升级套件发送授权证书。
授权证书提供了如何将其兑换为仪器选项111的许可证密钥的说明。 如果您没有授权证书,请致电当地的Agilent呼叫中心,让他们从您的订单号或序列号中查找。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - An entitlement certificate should have been sent with the option 111 upgrade kit. The entitlement certificate gives instructions how to redeem it for a license key for option 111 for your instrument. If you don’t have the entitlement certificate, please call your local Agilent Call center and ask them to look it up from your order number, or serial number. Regards - |
醉狼工作室 发表于 2019-1-15 14:53 我没有证书,我也不知道订单号,我已经用串口#打电话给呼叫中心,但他们无法找到任何111 bein许可MY4530516的记录所以我死在这里,该单位来自霍尼韦尔盈余和 他们对此没有任何线索! 我读到所有带有MY46及更高版本的型号都带有111标准版,所有硬件都在我的乐器中,所以为什么要获得一个代码字来实现这个呢? 甚至更好的为什么你需要一个像USB接口一样基本的代码字来开始? 像这样的东西应该即插即用!!!! 这个仪器对我们来说是一个主要的购买,我们选择这个的原因之一是USB接口,如果我当时知道这个接口没有启用,并且这是一个令人头疼的打开然后我 本来可以购买一台带有USB的R + S乐器! 我对此并不满意! 以上来自于谷歌翻译 以下为原文 i dont have the certificate neither do i know the order number , i already called the call center with the serial# but they couldnt find any record of 111 bein licensed for MY4530516 so im at a dead end here, the unit came from honeywell surplus and they dont have a clue about this ! i read that all models with MY46 and higher come with 111 standart and all the HW is there in my instrument so why is it such a headache to get a codeword to enable this ? or even better why do you need a codeword for something as basic as a USB interface to beginn with ? something like this should be plug and play !!!! This instrument was a major purchase for us and one of the reasons we chose this one was the USB interface , if i had known at the time that this the interface is not enabled and that it is such a headache to get this turned on then i would have bought a R+S instrument which has USB in there ! i am not happy about this ! |
Hi -Since选项111成为US / MY / SG4618序列前缀的标准中途,由于您拥有必要的硬件,我们继续为您的仪器生成许可证密钥(E4440A,MY45305016)。
选项111的许可证密钥是82A30C5B5E22Regards - 以上来自于谷歌翻译 以下为原文 Hi - Since option 111 became standard half way through the US/MY/SG4618 serial prefix, and since you have the necessary hardware, we went ahead and generated a license key for your instrument (E4440A, MY45305016). Your license key for option 111 is 82A30C5B5E22 Regards - |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1842浏览 0评论
415浏览 0评论
/9
GMT+8, 2025-12-1 16:00 , Processed in 2.669435 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1497
