电子发烧友论坛|
您好!
我使用自动输出模式设置传输。所有的PC机发送到设备的传输使用GPIF转移。 不幸的是,我需要跳过第一个数据包,发送300个数据包,跳过301包,300包传输等。 在theisr_ep2inout我检查数据包的内容,试图忽略它之前设定的GPIF转移。 代码: EP2FIFOCFG=0x01;/手动模式 同步延迟; OutpkTurnices=0x82//跳过分组 同步延迟; ep2fifocfg = 0x11;/ /回到自动模式,禁用pktend零长发,字行动 同步延迟; 不起作用。包不跳过和GPIF转移捡起来。如果我用另一个代码FIFO复位(从TRM):fiforeset = 0x80;/ /激活nak-all避免竞争条件syncdelay;ep2fifocfg = 0x01;//切换到手动模式syncdelay;fiforeset = 0x02;/ /复位FIFO 2 syncdelay;outpktend = 0x82;/ /跳过包syncdel是的;ep2fifocfg = 0x11;//切换到自动模式syncdelay;fiforeset = 0x00;//释放NAKALL SYNCDELAY;然后我会跳过一个以上的数据包 有什么办法跳过整整一包从EP2缓冲和保护人的完整? 以上来自于百度翻译 以下为原文 Hi I setup the transfer using the auto-out mode. Everything the PC sends to the device is transferred using GPIF transfer. Unfortunately, I need to skip the first packet, transmit 300 packets, skip 301 packet, transmit another 300 packets and so on. In the ISR_Ep2inout I check the packet content and try to ignore it before the setting the GPIF transfer. The code: EP2FIFOCFG = 0x01; // manual mode SYNCDELAY; OUTPKTEND = 0X82; // skip packet SYNCDELAY; EP2FIFOCFG = 0x11; // back to auto out mode, disable PKTEND zero length send, word ops SYNCDELAY; does not work. The packet is not skipped and GPIF transfer picks it up. If I use another code that resets FIFO (from TRM): FIFORESET = 0x80; // activate NAK-ALL to avoid race conditions SYNCDELAY; EP2FIFOCFG = 0x01; //switching to manual mode SYNCDELAY; FIFORESET = 0x02; // Reset FIFO 2 SYNCDELAY; OUTPKTEND = 0X82; // skip the packet SYNCDELAY; EP2FIFOCFG = 0x11; //switching to auto mode SYNCDELAY; FIFORESET = 0x00; //Release NAKALL SYNCDELAY; then I sometimes skip more than one packet Is it any way to skip exactly one packet from EP2 buffer and preserve others intact? |
1个回答
同时,我建议您为此创建一个技术支持案例(MyActudio & Gt;MyCox)。我们的工程师会调查这个问题。
当做, 西克里希纳。 以上来自于百度翻译 以下为原文 Meanwhile, I would recommend you to create a tech support case (MyAccount --> MyCases) regarding this. One of our engineer will look into this. Regards, sai krishna. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 05:38 , Processed in 0.672722 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2206
