电子发烧友论坛|
我在共振峰中看到有一个参数“温度”:带有K,C和C的子菜单。
F温度格式。 我查看帮助文件,但我没有看到任何迹象表明如何使用该格式。 我假设我们可以使用带热电偶的电压感应线作为温度检测器,然后使用公式计算适当的温度。 如果PNA-X在公式编辑器中包含最流行的热电偶系数公式,如K型等,那将是很好的。 目前我正在进行功率处理随着时间的推移,将温度记录器同时用于比较一次拍摄中的功率,损耗和温度,这将是很好的。 以上来自于谷歌翻译 以下为原文 I see in formant there is a parameter "Temperature": with sub menu with K, C & F temperature format. I look in to help file but I do not see any indication how to use that format. I will assume that we could use the voltage sensing lines with thermocouple as temperature detector and then using formula to calculate the proper temperature. It will be nice if the PNA-X contain in formula editor most popular thermocouple coefficients formula like for K-type and so on. Currently I am doing power handling over time and it will be nice to have temperature logger the same time to compare power, loss and temperature over time in one shoot. |
1个回答
最初将温度格式添加到格式选择中以支持在PNA-X的噪声系数应用中进行的噪声温度(T~eff_)测量(噪声温度是来自噪声功率测量的计算量)。
但是,您对标准公式中添加常见电压 - 温度转换因子的输入是一个有趣的建议,我们将考虑它。 另一方面,PNA-X(或运行最新固件的PNA)已经可以使用通用DC仪表外部设备直接从任何SCPI可控传感器读取温度。 !HTTPS://dl.dropbox.com/u/87949221/DCMeter.jpg! 以上来自于谷歌翻译 以下为原文 the temperature format was originally added to the format selection to support noise temperature (T ~eff~ ) measurements made in the PNA-X's Noise Figure application (noise temperature is a computed quantity from noise power measurements). However, your input about adding common voltage-temperature conversion factors to the standard equations is an interesting proposal and we'll take it under consideration. On the other hand, the PNA-X (or PNA's running the latest firmware) can already read temperature directly from any SCPI controllable sensor, using the generic DC Meter external device. !https://dl.dropbox.com/u/87949221/DCMeter.jpg! |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:12 , Processed in 1.803176 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2427
