嗨
我收到了对该设备的回复,我还有其他问题。 根据回复,对于一般IO,设备速度为800Mbps。 但是,我不知道确切的收发器,因为我不是这个领域的专业。 我只是自学成才。 在我的情况下,通过使用此设备,我将传输数据(1端口),并接收(也是1端口)。 是收发器还是不收发? 如果我只是传输一些位(数据),是否应用800mbps的速度或3.2到3.75 gbps? 我几乎可以使用任何针脚。 这些引脚功能相同吗? 我可以根据自己的喜好设置tx和rx的引脚吗? 对不起,我有很多问题,因为我的知识很浅薄。 谢谢。 以上来自于谷歌翻译 以下为原文 hi I received a reply to that device and I have additional question. according to the reply, for the general IOs, the device speed is 800Mbps. but, I don't know the exact transceiver, because I am not a major in this field. I am only self-taught. In my case, by using this device, I will transmit the data (1 port) , and receive( also 1 port). is it transceiver or not? if I simply transmit some bit(data), would a speed of 800mbps be applied or 3.2 to 3.75 gbps? and I can use nearly any pins. are these pins same function? Can I set pins for tx and rx to my liking? I am sorry that I have many questions because my knowledge is shallow. thank you. |
3个回答
根据您需要的接口,您可以通过三种不同的方式在Virtex 5上执行I / O操作。
(1)GTP / GTX收发器。 这是性能最高的选项,提供3.75Gbps或6.5Gbps(分别用于GTP和GTX收发器)。 收发器总是使用LVDS; 他们不做单端I / O. 它们仅适用于特定引脚,并且这些引脚不能用作通用I / O,因此您必须仔细选择引脚。 (2)SelectIO上的LVDS。 通用I / O引脚(SelectIO)可在LVDS模式下提供高达1250Mbps的速率。 这为放置提供了更大的灵活性; 有数百个SelectIO位置。 但是,要使用LVDS,您必须选择合适的引脚对。 (3)SelectIO上的单端。 SelectIO引脚可在单端模式下提供高达800Mbps的速率。 这允许您选择器件上的几乎任何引脚(除了特殊功能的引脚 - 电源,GTP / GTX,专用JTAG引脚等)。 您使用哪一个完全取决于您正在连接的设备。 以上来自于谷歌翻译 以下为原文 There are three different ways that you can do I/O on the Virtex 5, depending on what interfacing you need. (1) The GTP/GTX transceivers. This is the highest performance option, offering 3.75Gbps or 6.5Gbps (for GTP and GTX transceivers respectively). The transceivers always use LVDS; they don't do single-ended I/O. They're only available on specific pins, and those pins cannot be used as general-purpose I/O, so you have to select your pins carefully. (2) LVDS on SelectIO. The general-purpose I/O pins (SelectIO) can deliver up to 1250Mbps in LVDS mode. This gives far more flexibility in placement; there are hundreds of SelectIO locations. However, to use LVDS you do have to select appropriate pairs of pins. (3) Single-ended on SelectIO. The SelectIO pins can deliver up to 800Mbps in single-ended mode. This allows you to pick almost any pin on the device (any except special-function ones - power supplies, GTP/GTX, dedicated JTAG pins, etc). Which one you use depends completely on what device you are interfacing to. |
谢谢您的回复。
但我想知道GTP / GTX和LVDS是什么意思? 由于这些缩写,我不明白。 :( 谢谢 以上来自于谷歌翻译 以下为原文 thank you for your reply. but I wonder what mean are the GTP/GTX and LVDS? I don't understand due to these abbreviations. :( thank you |
Gilin和GTX是Xilinx在Virtex 5上称之为高速收发器的东西。新一代有GTH,GTY等。
LVDS是低压差分信号。 它每个信号使用两条线,数据作为这两条线之间的差异。 理想情况下,两根导线在电路板上彼此相邻布线,因此任何噪声都会以相同的方式影响它们,并且它们之间的差异(接收器所关心的全部)根本不受影响。 LVDS几乎用于所有高速串行数据接口(例如SATA,USB,DisplayPort等)。 以上来自于谷歌翻译 以下为原文 GTP and GTX are what Xilinx calls the high-speed transceivers on the Virtex 5. Newer generations have GTH, GTY, etc. LVDS is low voltage differential signalling. It uses two wires per signal, and the data is taken as the difference between those two wires. Ideally the two wires are routed next to each other on the circuit board, so any noise affects them both in the same way and the difference between them (which is all the receiver cares about) is not affected at all. LVDS is used for virtually all high-speed serial data interfaces (eg. SATA, USB, DisplayPort, etc). |
只有小组成员才能发言,加入小组>>
2173 浏览 7 评论
2611 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2082 浏览 9 评论
3153 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2199 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
433浏览 1评论
1531浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2181浏览 0评论
511浏览 0评论
1649浏览 0评论
GMT+8, 2024-5-3 23:45 , Processed in 0.988500 second(s), Total 81, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
