电子发烧友论坛|
嘿!
缓冲区如何在FX3中工作,从FIFO模式?每个物理线程是否分配缓冲区,或者每个逻辑套接字分配缓冲区? 奴隶FIFO总共有多少缓冲空间?如果我使用四个物理线程,每个线程只有一个套接字,每个物理线程有多少缓冲空间?如果我将2个逻辑套接字连接到每个物理线程,那么每个逻辑套接字现在只有一半的空间吗? 以上来自于百度翻译 以下为原文 Hey all - How does buffer space work in the FX3 for Slave FIFO mode? Are buffers allocated per physical thread, or per logical socket? How much buffer space is there total for Slave FIFO? If I use four physical threads, with only one socket per thread, how much buffer space does each physical thread have? If I attach 2 logical sockets to each physical thread, does each logical socket now only have half as much space? |
6个回答
RAM由代码和缓冲器共享。所以,你可以使用缓冲区的数量取决于固件的大小和你如何配置DMA通道缓冲区。
当做, 阿南德 以上来自于百度翻译 以下为原文 The RAM is shared by both code and buffer. So the amount of buffer that you can use depends on the firmware size and how you configure the buffer for the DMA channel. Regards, Anand |
Aasi -
谢谢你的回复。那么你能回答一个问题吗? 当配置缓冲区大小时,“缓冲区计数”值如何传递到DMA配置结构图到实际内存中?如果我设置DMAICONTIONCOUNT=2,因此分配2个缓冲区到那个DMA通道,那么内存是多少? 以上来自于百度翻译 以下为原文 Aasi - Thank you for the response. Can you answer one more question then: When you configure the buffer size, how does the 'buffer count' value passed into the DMA configuration struct map to actual memory? If I set dma_config.count = 2, and thus allocate 2 buffers to that DMA channel, how much memory is that? |
阿南德-
关于如何将DMA配置映射中的缓冲区计数设置为内存,您有什么文档吗? 以上来自于百度翻译 以下为原文 Anand - Do you have any documentation on how setting the buffer count in the DMA configuration maps to memory? |
我会一直努力直到我得到赛普里斯的回应。
以上来自于百度翻译 以下为原文 I'm going to keep bumping this until I get a response from Cypress. |
好吧,我想出来了。
缓冲区大小由DMA CONFIG中的“大小”参数配置,然后告诉每个DMA配置它们获得多少缓冲区。 现在,“线程堆栈大小”仍然是一个谜。 以上来自于百度翻译 以下为原文 Okay, I figured it out. Buffer sizes are configured by the 'size' parameter in DMA config, and then you tell each DMA config how many buffers they get. Now, 'thread stack size' is still a total mystery. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 22:56 , Processed in 0.796478 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2847
