电子发烧友论坛|
大家好,
对经验丰富的人来说应该很容易.. :) 在开发阶段,我使用Impact(SPI PROM)编程系统的PROM。 我想知道是否可以直接从SDK编程PROM。 我正在使用ISE(而不是Vivado),因为我正在使用较旧的平台。 具体来说,我尝试使用Xilinx工具 - >程序闪存 我收到一条错误消息: “在硬件系统中找不到可用的闪存控制器”。 Via Impact一切都很棒。 我究竟做错了什么? 是否有通过SDK进行编程的替代方法? 最好的祝福, 以上来自于谷歌翻译 以下为原文 Hello all, This one should be easy for the experienced.. :) During development phases, I am programming my system's PROM using Impact (an SPI PROM). I was wondering whether it is possible to program the PROM directly from the SDK. I am using ISE (not Vivado) since I'm working on an older platform. Specifically, I try Xilinx tools-> Program Flash I get an error message: "No usable flash memory controllers were found in the hardware system". Via Impact everything works fantastic. What am I doing wrong? Is there an alternative way of programming via the SDK? Best regards, |
2个回答
是的,您可以使用jTAGhttp://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/SDK_Doc/concepts/sdk_c_jtag.htmhttp://www.xilinx.com/support/documentation/sw_manuals/xilinx13_3/SDK_Doc/tasks/
sdk_t_configure_jtag.htmhttp://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/SDK_Doc/reference/sdk_u_configure_jtag.htm 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Yes you can use jTAG http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/SDK_Doc/concepts/sdk_c_jtag.htm http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_3/SDK_Doc/tasks/sdk_t_configure_jtag.htm http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/SDK_Doc/reference/sdk_u_configure_jtag.htm Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution.View solution in original post |
sdk_t_configure_jtag.htmhttp://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/SDK_Doc/reference/sdk_u_configure_jtag.htm 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Yes you can use jTAG http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_1/SDK_Doc/concepts/sdk_c_jtag.htm http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_3/SDK_Doc/tasks/sdk_t_configure_jtag.htm http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/SDK_Doc/reference/sdk_u_configure_jtag.htm Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 00:13 , Processed in 1.422220 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
467
