电子发烧友论坛|
我目前正在测试LIS2DH12的冲击检测和测量项目。
我的第一个问题是: 我必须在阈值寄存器中使用哪个缩放因子,以及在读取值中使用哪个缩放因子为+ - 16 g,低功耗模式(LP)。我是否认为他们与众不同? 读数值:192 mg / LSB 阈值寄存器(INT1_THS,INT2_THS):186 mg / LSB 我的下一个问题是关于最大有效范围 我在低功率模式下以5376 Hz测试了最大读数值+ -16 g。 在OUT寄存器内部,我确实在3轴中的一个或两个位置有8位+127或-128位。 这意味着:127 x 0.192 g = 24.384 g 这个值是否仍然正确,因为它比+ - 16g的最大范围高出10%以上? 非常感谢您的帮助! ( Batek.Miroslav â€OE) #out-of-range#lis2dh12 以上来自于谷歌翻译 以下为原文 I'm currently testing the LIS2DH12 for a project concerning shock detection and measurement. My first question is: Which scaling factor do I have to use at the threshold registers and which one at the readout values for +- 16 g, Low Power mode (LP). Do I get this right that they are different? Readout values: 192 mg / LSB Threshold registers (INT1_THS, INT2_THS): 186 mg / LSB My next question is about the maximum valid range I tested the maximum readout values at +-16 g in low power mode at 5376 Hz. Inside the OUT register I do have 8 bit-values of +127 or -128 at one or two out of the 3 axis. That would mean: 127 x 0.192 g = 24.384 g Is this value still correct because it's a bit more than 10 % above the maximum range of +- 16g? Many thanks in advance for your help! ( Batek.Miroslav ‌) #out-of-range #lis2dh12 |
4个回答
你好,
看看我之前的一个问题的答案(它与磁力计有关,但原理是相同的)。 https://community.st.com/thread/40903-lis3mdl-data-interpretation&sharpcomment-157236 长话短说:如数据表中所述,边界得到保证,边界外的值不能保证有意义。 大卫 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello, Have a look at this answer to one of my previous question (it is related to a magnetometer, but the principle is the same). https://community.st.com/thread/40903-lis3mdl-data-interpretation&sharpcomment-157236 Long story short: boundaries are guaranteed as stated in the datasheet, the values outside the boundaries are not guaranteed to be meaningful. David Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
16g以上的功能无法保证。
输出可以不是线性的,可以逐个变化 以上来自于谷歌翻译 以下为原文 The functionality above the 16g is not guaranteed. The output can be not linear and can vary piece by piece |
嗨大卫,
非常感谢您的回复! 您是直接来自ST支持团队吗?我只是想知道这个Info是否正式有效,因为我想在生产代码中使用该解决方案。 最好的祝福 菲利普 以上来自于谷歌翻译 以下为原文 Hi David, Many thanks for your reply! Are you directly from the ST Support Team? I just wanted to know if this Info is officially valid because I want to use the solution in production Code. Best regards Philipp |
菲利普你好,
我不是ST员工,但是我链接到你的回复是由我写的 Batek.Miroslav ,,谁是ST员工,所以我会考虑这个官员。最好的问候, 大卫 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello Phillipp, I am not an ST employee, however, the reply I linked you to was written by Batek.Miroslav ‌, who is an ST employee, so I would consider this official.Best Regards, David Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 05:15 , Processed in 0.923789 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3534
