扫一扫,分享给好友
你好。
我必须使用手动DMA模式。我在DMA回调函数中引用了示例源“Cyu3PDMACHANNEL DISCUBASH缓冲区”函数。 USB工作很好。但是性能很低。我认为“CYU3PDMACHANNEL DISCARBASH”功能消耗太多。 在DMA回调函数中删除“CYU3PDMACHANNEL DISCUBASH”函数。DMA回调函数只工作一次。 我想在没有“CYU3PDMACHANNEL DISCUBASH”功能的情况下重用DMA缓冲区。 请让我知道怎么做。 当做。 小腿。 以上来自于百度翻译 以下为原文 Hi. I have to use MANUAL DMA mode. I referenced example source what "CyU3PDmaChannelDiscardBuffer " function in DMA callback function. USB working is good. but performance is very low. I think "CyU3PDmaChannelDiscardBuffer" function consume resources too much. I remove "CyU3PDmaChannelDiscardBuffer" function in DMA callback function. DMA callback function is worked just one time. I want to reuse DMA buffer without "CyU3PDmaChannelDiscardBuffer" function. Please Let me know how to do. Regards. Shin. |
1个回答
一旦FX3接收到数据,它很可能会坐在DMA缓冲器中。除非您读取数据(或消耗到其他端口),否则数据将保留在那里。缓冲区将被占用,您将无法获得任何进一步的DMA回调。类似的是这里的情况,DMA缓冲区可能已经满了(因为您不丢弃数据),因此不会生成任何其他回调。如果你不通过任何可用的端口消耗数据,就必须使用EXY3PDMACHANNEL DISCULD缓冲区。
你的意思是你得到了性能问题。请解释并分享你的固件。你检查了UBBulkStudioSink固件吗?在这里,我们丢弃从主机接收的每个DMA缓冲区,并且我们没有注意到任何性能问题。 以上来自于百度翻译 以下为原文 Once the FX3 receives the data, it is likely to be sitting in the DMA buffers. Unless you read the data (or consume is to some other port), the data will remain there. The buffers will be occupied and you will not get any further DMA callback. Similar is the situation here, the DMA buffer might have got full (as you are not discarding the data), so any further callbacks won't be generated. You have to use CyU3PDmaChannelDiscardBuffer if you are not consuming the data through any available port. What do you mean that you are getting performance issue. Please explain and share your firmware. Have you checked the USBBulkSourceSink firmware? There we are discarding every DMA buffer received from the host and we have not noticed any performance issues. |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3672 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1788 浏览 6 评论
1536 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
575浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
428浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
439浏览 2评论
389浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
921浏览 2评论
GMT+8, 2024-12-26 15:39 , Processed in 0.905283 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
