电子发烧友论坛|
我希望通过GIC从PL到PS中断。这里的中断发生器是AXI定时器。中断ID是61.我在Xilinx SDK中使用API作为独立应用程序,基于中断完成了一些任务(在ISR中定义)。
但我想使用下面的一个函数xil_out32.like与上面相同 //设置中断使能寄存器。 偏移= 0x100 + dec_to_hex(76/32 * 4)= 0x108 Xil_out32(0x2c0c1000 + 0x108,0xFFFFFFFF); //将ICDIPTRn寄存器设置为cpu0。 偏移= 0x800 + dec_to_hex(76/4 * 4)= 0x84c Xil_out32(0x2c0c1000 + 0x84C,0x01010101); //将中断配置寄存器(ICDICFR0)设置为电平敏感。 偏移= 0xC00 + dec_to_hex(76/16 * 4)= 0xC10。 hw_write(0x2c0c1000 + 0xC10,0x0); //优先级掩码 启用最低优先级的中断Xil_out32(0x2c0c0100 + 0x4,0xFFFF); //启用中断信号Xilinx_out32(0x2c0c0100 + 0x0,0x3); //配置分配器控制寄存器(ICDDCR)以将待处理中断发送到cpus Xilinx_out32(0x2c0c1000 + 0x000,0x1); 因此,任何产生中断且其中断线连接到IRQS [44]的外设,GIC都会检测并将其发送到CPU0。 我的问题是 我们如何使用上述方法定义和映射ISR? 以上来自于谷歌翻译 以下为原文 I want to take interrupt from PL to PS through GIC.Here interrupt generator is AXI timer.And Interrupt ID is 61.I did some tasks(defined in ISR) based on interrupt by using APIs for standalone application in Xilinx SDK. But I want to do same as above using one function xil_out32.like below // Set Interrupt Enable Registers. Offset = 0x100 + dec_to_hex(76/32*4) = 0x108 Xil_out32(0x2c0c1000 + 0x108, 0xFFFFFFFF); // Set ICDIPTRn Registers to cpu0. Offset = 0x800 + dec_to_hex(76/4*4) = 0x84c Xil_out32(0x2c0c1000 + 0x84C, 0x01010101); // Set Interrupt Configuration Registers (ICDICFR0) to level sensitive. Offset = 0xC00 + dec_to_hex(76/16 *4) = 0xC10. hw_write(0x2c0c1000 + 0xC10, 0x0); // Priority Mask. Enable interrupts for lowest priority also Xil_out32(0x2c0c0100 + 0x4, 0xFFFF); // enable signaling of interrupt Xilinx_out32(0x2c0c0100 + 0x0, 0x3); // Configure the Distributor Control Register (ICDDCR) to send pending interrupts to cpus Xilinx_out32(0x2c0c1000 + 0x000, 0x1); So any peripheral that generates an interrupt and whose interrupt line is connected to IRQS[44] , the GIC will detect and send it to CPU0. Here my question is How can we define and map ISR by using above method? |
1个回答
我已经分享了我的代码。
检查一下然后告诉我如何将ISR添加到上面的逻辑中。 以上来自于谷歌翻译 以下为原文 I have shared my code. Check it and then tell me that how could we add ISR to above logic. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 01:10 , Processed in 1.506390 second(s), Total 75, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
690
