电子发烧友论坛|
我正在使用MPLAB-X进行代码移植项目。我已经打开了这个项目(由其他人准备X)。现在我添加了一个新的C文件并开始编写代码。但是,在左下角的面板中,可以看到编辑文件中的函数。(没有关联项目)这意味着什么?请注意,我从MPLAB-X中创建了新文件,并加载了项目…
以上来自于百度翻译 以下为原文 I am using MPLAB-X for a code porting project. I have opened the project (prepared for X by someone else). Now I added a new c file and started writing code. But the panel to the lower left where one can see the functions in the edited file etc, shows a message in red on top saying: Limited code assistance (no associated project) What does this mean? Note that I created the new file from within MPLAB-X with the project loaded.... |
3个回答
您没有指定MPLABX版本。可能是一个被固定的bug:HTTPS://NETBANS.Org/BugZiLa/SujiBu.CGI?ID= 2567 898或文件与您的项目不相关(虽然您认为是)。
以上来自于百度翻译 以下为原文 You did not specify your MpLabX version. Could be a bug which is fixed already https://netbeans.org/bugzilla/show_bug.cgi?id=256789 or the file is really not associated with your project (though you think it is). |
嗨,在MPLAB X中,在左上面板的“项目”中,有一个层次的所有文件都是你的项目的成员。你的新文件是否存在?如果不是,请通过指向“源文件”来介绍新文件,单击右键并选择“添加现有项……”MysIL。
以上来自于百度翻译 以下为原文 Hi, In MPLAB X, in the upper left panel 'Projects', there is a hierarchy of all files that are members of your project. Is your new file present in there? If not, introduce your new file by pointing to 'Source Files', click righthand button and select 'Add Existing Item...' Mysil |
我选择了“文件”选项卡,在这个视图中显示了文件。当我创建文件时,我点击这里并选择了“新/源文件”。当我移动到Project选项卡并展开我的项目时,我不再看到文件/文件夹层次结构,而是文件类型的层次结构,所以我选择了“源文件”。在这里,我的新文件是不可见的,但我可以将它添加到项目中,如您所描述的。
以上来自于百度翻译 以下为原文 I had the tab "Files" selected and in this view the file is shown. And it was here I right-clicked and selected "New/SourceFile" when I created the file. Seemed the logic thing to do. When I move to the Projects tab and expand my project I no longer see the file/folder hierarchy, but a hierarchy of types of files, so I selected "Source Files". Here my new file was not visible. But I could add it to the project as you describe. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-1 22:38 , Processed in 0.486462 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1769
