扫一扫,分享给好友
Xilinx又有了新的网页设计,现在我再也找不到网页链接了。
>>“开放服务请求”这不是webcase吗? 那么我在哪里打开一个webcase? 以上来自于谷歌翻译 以下为原文 Xilinx has again new web design, and now I can not find the webcase link anymore. >> "Open Service Request" this is not webcase right? so where do I open a webcase? |
10个回答
@trenz-al我认为自上次更改以来,这是您第一次访问SR页面。
等待几分钟,如果您仍有问题,请告诉我们 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @trenz-al I think since last changes this is the first time you are visiting SR page. Wait for few mins and let us know if you still having problem -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
你好@ TRENZ-人,
Xilinx升级了支持门户。 您需要登录以下链接,然后提出服务请求。 http://www.xilinx.com/support/service-portal.html 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @trenz-al, Xilinx has upgraded the support portal. You need to login at below link and then raise Service Request. http://www.xilinx.com/support/service-portal.html Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
@trenz-alWebcase被称为服务请求的东西改了。
转到suppprt并单击打开服务请求 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @trenz-al Webcase got changed with something called service request. Go to suppprt and click on open a service request -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
但为什么这个“东西”就像你所说的那样,请问我
根据我们的记录,您是第一次使用。 !? 我不是第一次使用者。 我们是Xilinx认证联盟的合作伙伴,过去我也开设过网络摄像头。 到底是怎么回事? 以上来自于谷歌翻译 以下为原文 but why does this "something" as you call it, ask me to According to our records, you are a first time user. !? I am not first time user. We are Certified Xilinx Alliance Partner, and I have opened webcases in the past. What is going on? |
@ TRENZ-人,
您是否无法使用以下链接打开以前称为WebCase的服务请求? http://www.xilinx.com/support/service-portal.html --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @trenz-al, Are you not able to open Service Request which was perviously called WebCase using the below link? http://www.xilinx.com/support/service-portal.html --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
没有,。
它要求我登录 然后继续点击下一步 然后承诺在接下来的“几分钟”内发送电子邮件 但就是这样...... 以上来自于谷歌翻译 以下为原文 no,. it asks me to login then to PROCEED to click next then promises send email in the next "few minutes" but thats it what happens.. |
等待几分钟,如果您仍有问题,请告诉我们 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @trenz-al I think since last changes this is the first time you are visiting SR page. Wait for few mins and let us know if you still having problem -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我在等
但是我们的客户不是,而且他们这么说 运用 IBUFDS-DIFF-OUT 只有一个ouptut连接(如信号反转)是不允许的,因为它给出了DRC警告 因为这没有真正记录在案,我唯一的选择就是询问webcase案例是什么 http://forums.xilinx.com/t5/7-Series-FPGAs/IBUFDS-DIFF-OUT-using-single-output/td-p/649514 安蒂 以上来自于谷歌翻译 以下为原文 I am waiting but our clients are not, and they say that using IBUFDS-DIFF-OUT with only one ouptut connected (like for signal inversion) is not ALLOWED as it gives DRC warning as this is not really documented my only choice is to ask webcase what the case is http://forums.xilinx.com/t5/7-Series-FPGAs/IBUFDS-DIFF-OUT-using-single-output/td-p/649514 Antti |
@ TRENZ-alOkay。
无论如何我在那个帖子上给你回复。 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @trenz-al Okay. anyways I gave you reply on that thread. -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好@ TRENZ-人,
你能检查一下你是否能够提交SR(服务请求)。 如果是,那么请关闭此主题。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @trenz-al, Can you check if you are able to file SR (Service request) now. If yes, then please close this thread. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2405 浏览 7 评论
2812 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2283 浏览 9 评论
3364 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2449 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
840浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
565浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
420浏览 1评论
1992浏览 0评论
715浏览 0评论
GMT+8, 2024-12-13 08:30 , Processed in 1.409497 second(s), Total 96, Slave 80 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
