电子发烧友论坛|
IAM使用PSoC 1 CY29 466单片机。我发现内部ADC对我的项目没有足够的分辨率或线性度。我决定使用ADS1211 ADC。它需要一个三线SPI接口。你能给我指出一个例子,从外部ADC写和读吗?
谢谢您, 菲利普 以上来自于百度翻译 以下为原文 I am using the PSoC 1 CY29466 MCU. I discovered the internal ADC do not have enough resolution or linearity for my project. I decided to use ADS1211 ADC. It takes a three wire SPI interface. Can you point me in a direction for examples to write and read from the external ADC? Thank You, Philip |
4个回答
你好,菲利普,
我同意ADC提供不具有良好的分辨率和介绍了一些偏移但有几个应用程序使用说明,员工的技术称为相关双采样(CDS)测量信号。APP不在这里:HTTP://wwwyCysP.COM/?摆脱= 2894explains,方法详细举例说明如何测量热电偶信号,分辨率要求为40uv低。 如果你想要一些代码例子SPI然后让我知道你的邮箱地址,我会把你的项目。 最好的问候, 普什克 以上来自于百度翻译 以下为原文 Hello Philip, I agree that the ADC provided does not have good resolution and it introduces some offset but there are a few app notes available which employees a technique called Correlated Double Sampling (CDS) to measure the signal. App not available here: http://www.cypress.com/?rID=2894 explains that method in detail with an example of how to measure signal of a thermocouple, where resolution required is as low as 40uV. If you want some code examples for SPI then let me know your email address, I shall be able to send you the projects. Best regards, Pushek |
我喜欢在SPI代码上提供帮助。我花了一个周末寻找SPI代码到ADS1211 ADC。我收到了一些很好的回应,一些回应应该放在糟糕的名单中。如果我能使13位线性,那将是伟大的。我最终将需要解决SPI代码问题。
谢谢您, 菲利普 以上来自于百度翻译 以下为原文 I would love help on SPI code. I spent the weekend looking for SPI code to a ADS1211 ADC. I received some nice responses and some responses that should be put in the nasty list. If I can make the 13 bit linear that would be great. I will eventualy need to solve the SPI code problem. Thank You, Philip |
创建一个SPI代码和.h文件与TI ADS1211进行通信会很困难吗?
谢谢您, 菲利普 以上来自于百度翻译 以下为原文 Would it be very difficult to creat a SPI code and .h file to communicate with the TI ADS1211? Thank You, Philip |
我确实看了应用笔记。它不会打开。它抱怨一个CMX问题。我打开了.c文件。即使我能得到我的13位广告工作0%错误。我能得到的最好的结果是+/- 0006。这是微不足道的。我的顾客想要X.XXX。因此,我被迫使用高精度ADC IC。你有没有SPI代码的样本和ADCS说话?我对SPI代码感到困惑。
谢谢 菲利普 以上来自于百度翻译 以下为原文 I did look at the app note. It would not open. It complained about a cmx problem. I opened the main.C file. Even if I could get my 13 bit AD working with 0% error. The best I could acheive would be +/- .0006. This is marginal. My custumer wants x.xxx. So I am forced into using a high accuracy ADC IC. Do you have any sampls of SPI code talking to ADCS? I am stumped on the SPI code. Thanks Philip |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 18:37 , Processed in 0.893427 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1883
