电子发烧友论坛|
你好,
我想使用两个PSOC1芯片,它们将以相同的频率工作,并且它们的时钟接近完美的相位对齐。 你能提出可行的选择来实现这个目标吗? 谢谢 以上来自于百度翻译 以下为原文 Hi, I want to use two PSOC1 chips which will operate at same frequency and their clocks near to perfect phase aligned. Can you please suggest feasible options to achieve this? Thanks |
5个回答
设置一个芯片在引脚上有一个12 MHz的时钟输出。将此信号路由到另一设备上的P1.4,在PSoC设计器中选择外部时钟源。
丹尼斯 以上来自于百度翻译 以下为原文 Set one chip to have a clock output at 12 MHz on a pin. Route this signal to P1.4 on the other device, select external clock source in PSoC Designer. ---- Dennis |
你能同时在两个不同的芯片上执行同一个程序吗?如果是这样,则需要它们之间的同步特性,因为它们可能不是完全并行的,所以有一些不可计算的延迟。
如果你告诉我们更多关于你想要完成的事情,我们可能会更好地帮助你。 鲍勃 以上来自于百度翻译 以下为原文 Can it be that you want to execute the same program simultanously on two different chips? If so, you'll need a synchronization feature between them, since they may not startup perfectly parallel, there are some uncalculatable delays. If you tell us a bit more about what you want to accomplish we might help you better. Bob |
如果你想要一个真正同步的处理器,就像医学中使用的一样。
药物输送应用,您需要一个复位引脚控制 启动内部CPU状态机,当然没有模拟 数字进程驱动逻辑,除非重新同步。 PSoC 1启动是由外部电压VDD斜坡内部控制的。 所以只需要一个低抖动时钟并将两个PSoC设置为外部时钟 不够。如果您希望它们同时执行相同的代码 及时点。 HTTP://www. CyPress?COM/?RID=58522 AN73617 正如鲍伯所说,对你要做的事情有更确切的描述。 乐于助人。 问候,Dana。 以上来自于百度翻译 以下为原文 If you wanted a truly synched pair of processors, like used in medical drug delivery applications, you would need a reset pin that controls startup of the internal CPU state machine, and of course no analog to digital processes driving logic, unless re-synched. PSOC 1 startup is internally controlled from external voltage Vdd ramp. So to just take a low jitter clock and set both PSOCs to external clock would not suffice. Thats if you want them both executing the same code at the same point in time. http://www.cypress.com/?rID=58522 AN73617 As Bob stated, a more definitive description of what you are trying to do would be helpful. Regards, Dana. |
谢谢你的回复。我想同步操作两个PSoC芯片的CAPSENSE模块(时钟,屏蔽信号是同相)。够清楚了吗?
以上来自于百度翻译 以下为原文 Thanks for the response. I want to operate Capsense modules of both PSOC chips in synchronization (clock, shield signal are to be in phase). Is that clear enough? |
由于CapSense不是一个被动的过程,而是一个活跃的,其中一些C被充电和测量,一个PSoC芯片将影响其他当使用CAPSENSE在相同的按钮/滑块上。此外,不能保证两个PSoCs都从复位同步器中出来。所以你的解释还不够。剩下的问题是:这两个PSoC背后的想法是什么?
鲍勃 以上来自于百度翻译 以下为原文 Since CapSense is not a passive process but an active one where some C is charged and measured one PSoC chip will influence the other when using CapSense on the same buttons / sliders. Additionally it will not be guaranteed that both PSoCs come out of reset synchron. So your explanation will not be enough. The remaining question is: What is the idea behind those two PSoCs, what job ( mission are you trying to accomplish this way? Bob |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 07:02 , Processed in 0.718994 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2066
