电子发烧友论坛|
喜
我为pcie gen1 ops配置了V6 gtx phy,并且运行良好。 然而,我设置phy的方式是它使用板载100M osc。 作为refclk,它使用这个100M clk进入FPGA PLL来获得pcie pipe_clk(125MHz)。 这个方案对我来说很好。 和pcie链接很好。 然而,当我更改phy以使用来自pcie插槽本身的100M refclk时,系统不起作用,即不会发生pcie链接。 我已经检查过,我有正确的引脚从pcie插槽中点击100M refclk。 我的问题 - 1)用于FPGA的xilinx gtx phy是否支持SSC时钟? 2)如果我在主机端启用或取消了SSC时钟,那么我需要在gtx phy中处理所有参数吗? 3)当我使用onchip 100M osc来获取refclk但是当我使用来自pcie插槽的时钟时,fpga设置可靠地工作的任何指针? 任何有指针的pcie + fpga大师? 帮助非常感谢... 谢谢, ž。 以上来自于谷歌翻译 以下为原文 hi, i have configured the V6 gtx phy for pcie gen1 ops and its working well. however the way i've setup the phy is that it uses an onboard 100M osc. as refclk and it uses this 100M clk going into the fpga PLL to get the pcie pipe_clk (125MHz). this scheme works fine for me. and pcie link up is good. however when i change the phy to use the 100M refclk from the pcie slot itself, the system does not work, i.e. the pcie link up does not happen. i've checked and i have the correct pins to tap the 100M refclk from the pcie slot. my questions - 1) does the xilinx gtx phy for FPGA support SSC clock? 2) if I have the SSC clock enabled or di***aled on the host side, what all parameters do i need to take care of in the gtx phy? 3) any pointers as to why the fpga setup works reliably when i use the onchip 100M osc to derive the refclk but does not work when i use the clock from the pcie slot? any pcie+fpga gurus with pointers? help is greately appreciated ... thanks, z. |
1个回答
你检查了trn_reset_n信号是否被断言。
如果断言,检查收发器PLL和放大器是否存在。 Fabric PLL被锁定。请参考以下答案记录; http://www.xilinx.com/support/answers/34873.htmlhttp://www.xilinx.com/support/answers/34894.html 以上来自于谷歌翻译 以下为原文 Have you Checked the trn_reset_n signal is it asserted. if it is asserted check if the Transceiver PLL & fabric PLL are locked. Please refer to the following answer records; http://www.xilinx.com/support/answers/34873.html http://www.xilinx.com/support/answers/34894.html |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 19:24 , Processed in 0.975631 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2496
