如果Ireceive a DMAbuffer从GPIF(即我得到回调),我可以使用DMAbuffer通过它到CYU3PDMACHANNETSUPUSTEN缓冲区吗?
我能创建一个“假”CYU3PDMABUFEFART,其中缓冲区指向另一个DMA通道正在使用的内存中的位置吗? 例如,我可以调用CYU3PDMACHANNETGETBuffic来获得一个刚刚完成的DMATANSFER的CYU3PDMABUFEFART,然后将其传递给CYU3PDMACHANNETSUPUSTEnEdfRAMP,以执行相同的缓冲区,而没有内存复制到输出的DMAChank? 同样,我可以通过使用CYU3PMEMOLARC分配我自己的CYU3PDMABUFEFART,然后填充字段以使其看起来像CYU3PDMABUFFER? CYU3PDMABUFFEFRYT*MYYMAD=(CYU3PDMABUFEFURTH*T*)CYU3PMEMOLATC(SIZEF(CYU3PMEMOLATC)); MyAdDMA.Puffel= p;/*内存中的某个位置,它是另一个信道上的DMA存储器的一部分* 计数=1; MyIdDMA.Stase= LangthytoTyTrime//*内存量传输*// MyydMA.Stase=????/不确定应该在这里,也许CYU3PDMAODEDET*T/ 以上来自于百度翻译 以下为原文 If I receive a DMA buffer from the GPIF (that is I get a callback) can I use the DMA buffer by passing it to CyU3PDmaChannelSetupSendBuffer? Can I create a "fake" CyU3PDmaBuffer_t where the buffer field points at a location in memory that another DMA channel is using? For example can I call CyU3PDmaChannelGetBuffer to get a CyU3PDmaBuffer_t for a DMA transfer that just completed, and then pass that to CyU3PDmaChannelSetupSendBuffer to commit the same buffer with no memory copying to the outgoing DMA channel? Likewise can I allocate my own CyU3PDmaBuffer_t by using a CyU3PMemAlloc and then populate the fields to make it looks like a CyU3PDmaBuffer_t? CyU3PDmaBuffer_t *my_dma = (CyU3PDmaBuffer_t *)CyU3PMemAlloc(sizeof(CyU3PMemAlloc)); my_dma.buffer = p; /* some location in memory that is part of a dma memory on another channel */ my_dma.count = 1; my_dma.size = length_to_transfer; /* amount of memory to transfer */ my_dma.status = ???; /* not sure what should go here, maybe CyU3PDmaMode_t */ |
1个回答
嗨,奥利弗,
请为此创建一个技术支持案例(MyActudio & Gt;MyCases),这样我们的一个工程师可以更仔细地研究你正在尝试实现的方法。 当做, 阿南德 以上来自于百度翻译 以下为原文 Hi Oliver, Please create a tech support case (MyAccount->MyCases) for this so that one of our engineers can have a closer look at the methodology you're trying to implement. Regards, Anand |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 04:54 , Processed in 0.649325 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3411
