电子发烧友论坛扫一扫,分享给好友
你好,
我有一个2输入,3位宽和门。我想提供相同的信号(这是来自一个单位宽非门)到所有3位的第二输入到与门。 我尝试遵循PSoC创建者帮助主题“绘制总线”的指令,但是不管IDEO中的顺序是什么,都会出现错误。通常“没有实例输入”和“1”,“终端”TMM1[2:0]。我曾经尝试过一些方式,甚至抱怨在“非门”的终端“终端”上没有输入,我无法想象这个消息甚至意味着什么。 有人能陪我走过吗?不可能复杂,但我被难住了。 谢谢, 道格 以上来自于百度翻译 以下为原文 Hello, I have a 2-input, 3-bit-wide AND gate. I'd like to supply the same signal (which is coming from a single-bit-wide NOT gate) to all 3 bits of the second input to the AND gate. I tried following the instructions in the PSOC Creator help topic 'Drawing Buses' but no matter what order I do things in I always end up with errors. Usually "No input on instance "and_1", terminal "term1[2:0]". Some ways I have tried even complain that the is no input on the terminal "outTerminal" of the NOT gate, I can't imagine what that message is even trying to mean. Could someone please walk me through this? I no it can't be complicated, but I am stumped. Thanks, Doug |
2个回答
嗨,道格,
我和一位应用工程师谈过这个问题,因为我不确定这是否可能。 一般来说,Creator不支持将一个比特直接连接到总线输入信号。您看到的错误是Creator报告,ANDGATE上的输入端有未连接的信号。 我附上了一个示意图供参考。在附件中,我们使用中间逻辑来创建用于与门上的输入的总线。当您构建时,所有中间逻辑都被优化了。 假设ANDGATE上的其他输入是特定原因的总线。在这里,我们使用的引脚组件配置有3个引脚。 希望这有帮助! Nojand和StoPiga.JPG 176.7 K 以上来自于百度翻译 以下为原文 Hi Doug, I spoke with an Apps Engineer about this because I wasn't sure if this was possible. In general, Creator doesn't support directly connecting a single bit to a bus input signal. The error your seeing is Creator reporting that the input terminal on the AND gate has unconnected signals. I've attached a schematic image for reference. In the attached, we used intermediate logic to create a bus for the input on the AND gate. When you build, all this intermediate logic is optimized out. The assumption is that the other input on the AND gate is a bus for a specific reason. Here, we just used a Pins component configured with 3 pins. Hope this helps!
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7367 浏览 0 评论
2486 浏览 1 评论
2178 浏览 1 评论
4045 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2089 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7865浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6430浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
759浏览 2评论
730浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8276浏览 2评论
/9
GMT+8, 2025-12-14 09:38 , Processed in 0.620658 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
698
