电子发烧友论坛|
我用的是第一触摸PSOC 3工具包。我有一个1.5V的峰-峰值40kHz的信号进入我的ADC,我由1.5V抵消这种信号,介于0和3 V之间我在30kHz的信号采样(采样率)。我在8位单模式设置ADC、Vssa和VDDA之间运行。
我的问题是,接收到的ADC值应介于0和接近255,但实际上有125和126之间(中心线)。问题是什么? 以上来自于百度翻译 以下为原文 I'm using the FirstTouch PSoC 3 kit. I have a 1.5V peak - to - peak 40kHz signal coming into my ADC, and i've offset this signal by 1.5V so that it lies between 0 and 3 V. I'm sampling this signal at 30kHz (subsampling). I've set up the ADC in 8 bit Single mode, running between Vssa and Vdda. My problem is that the received ADC value should be varying between 0 and somewhere close to 255, but actually varies between 125 and 126 ( the centre line). What could the problem be? |
2个回答
你好,
你能提供一些更多的信息关于你的输入信号。你说它的1.5伏特峰到峰值?这意味着如果你添加一个1.5伏的电压偏移,信号将0.75伏和2.25伏之间变化。 还有如何配置ADC,哪种模式。你如何看ADC的价值? -乌达扬 以上来自于百度翻译 以下为原文 Hi, Can you provide some more information about your input signal. You said its 1.5 Volts peak to peak? that means if you add a 1.5 Volts offset, the signal will vary between 0.75 Volts and 2.25 Volts. Also how have configured the ADC, which mode. How are you reading the values from ADC. -Udayan |
HiMechatronicsMan
我不相信你不能使用西格玛-德尔塔转换器来进行子采样。操作的原理是高度过采样输入,然后使用动态校正和数字滤波器,以降低到最终采样率。对于您的应用程序,您可能会更好地使用PSoC5。它有一个SAR ADC,其中子采样应该工作得很好。或者,你可以使用混合器。 尝试新的KIT-050进行模拟设计。 凯利C 以上来自于百度翻译 以下为原文 Hi MechatronicsMan, I don't believe that you cannot use the Sigma-Delta converter to sub-sample. The principle of operation is to highly oversample the input and then use dynamic correction and digital filters to reduce to the final sample rate. For your application, you may be better off with the PSoC5. It has a SAR ADC, where the sub-sampling should work just fine. Alternatively, you can use the mixers. Try the new Kit-050 for analog designs. Kelly C. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 04:37 , Processed in 0.649394 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
508
