你好,
我正在尝试在我的设备上运行以太网1000baseX协议。 我的设备是Kintex7运营卡,其上有一个带有四个SFP的FM-S14子卡连接到运营商卡。 我正在研究以太网1000base的示例设计。 我对它的输入有一些疑问。 起初我试图在没有MAC或外部GMII协议的情况下测试这个协议。 因此,对于输入数据(gmii_txd),我编写了一个与userclk2(基本系统时钟)配合使用的计数器。 这些数据将转到gig_eth_pcs_pm_core IP核。 当我检查此IP核的txdata [7:0](输出数据为8b10b编码)时,它会显示以下信号。 重要的是告诉你它用gmii_txd的每个值向我展示这个信号,这意味着它独立于此。 你能否指导一下1000base ipcore的txdata的价值。 谢谢 以上来自于谷歌翻译 以下为原文 Hello, I'm trying to run ethernet 1000baseX protocol on my device. My device is Kintex7 carrier card that a FM-S14 daughter card with four SFP on it was attached to carrier card. I'm working on example design of ethernet 1000base. I have some question about its input. At first I'm trying to test just this protocol without MAC or external GMII protocol. So, for input data (gmii_txd) I've written a counter that works with userclk2(te basic system clock). this data will go to gig_eth_pcs_pm_core IP core. when I check the txdata[7:0] (output data that go to 8b10b encoding) of this IP Core it shows me the below signals. It's important to tell you its show me this signal with each value of gmii_txd and it means it's independent of that. Could you please guide me about the value of txdata of 1000base ipcore. Thanks |
1个回答
嗨Huppa,
我不确定你对txdata接口的要求到底是什么。 您可以快速模拟并检查数据,因为它在编码器之前和GT之前,我猜你在GMII接口上驱动的数据将在这里看到。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Huppa, I am not sure what exactly your requirement is with the txdata interface. you can do a quick simulation and check the data and as it is before the encoder and before the GT,i guess the data that you are driving at the GMII interface will be seen here. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2429 浏览 7 评论
2831 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2298 浏览 9 评论
3378 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2468 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1345浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
596浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
460浏览 1评论
2013浏览 0评论
738浏览 0评论
GMT+8, 2024-12-28 18:47 , Processed in 1.311128 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
