电子发烧友论坛|
我相信AXI Interconnect 2.1是Vivado 2013.3的最新产品吗?
但是,只有1.7版本出现在IP目录中(针对Virtex 7 690T的项目)。 我可以在data / ip下看到2.0和2.1文件夹,两者都列在vv_index.xml文件中。 但是对2.0 / 2.1版本有任何限制吗? 如何让更高版本在IP目录中正确显示? 谢谢。 以上来自于谷歌翻译 以下为原文 I believe AXI Interconnect 2.1 is the latest offering with Vivado 2013.3? However, only version 1.7 shows up in the IP Catalog (project targeting Virtex 7 690T). I can see the 2.0 and 2.1 folders under data/ip, and both are listed in the vv_index.xml file. But are there any restrictions on the 2.0/2.1 versions? How can I get the later versions to show up properly in the IP Catalog? Thanks. |
2个回答
嗨,
AXI互连1.7与2013.3一同发布,根据IP发行说明xtp025,这似乎是正确的,因为1.7将是1.6的下一个版本 http://www.xilinx.com/support/documentation/ip_documentation/xtp025.pdf 因此,您可以忽略data / ip下的2.0和2.1文件夹,因为该工具可以正确选择正确的版本。 我认为2.0和2.1可能正在开发中。 希望这可以帮助。 问候, Vanitha。 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, AXI interconnect 1.7 is released with 2013.3 and this seems correct as per IP release notes xtp025 as 1.7 would be the next version to 1.6 http://www.xilinx.com/support/documentation/ip_documentation/xtp025.pdf So you can ignore the 2.0 and 2.1 folder under data/ip as the tool picks the proper version correctly. I think 2.0 and 2.1 might be under development. Hope this helps. Regards, Vanitha. --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
嗨,
AXI Interconnect版本2.0及更高版本由上面的各个子模块组成,目前仅在IP Integrator中提供。 请参阅ARhttp://www.xilinx.com/support/answers/54453.htm --Hem -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 Hi, The AXI Interconnect version 2.0 and later is composed of the individual sub-modules above, and is currently only available in IP Integrator. Refer to the AR http://www.xilinx.com/support/answers/54453.htm --Hem ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 08:36 , Processed in 0.629174 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
904
