你好,ti的工程师:
我配置tvp7002为1920x1080 60分辨率,可显示到电视上没有满屏,感觉是行缩放了,调了几天 ,没点思路,希望能得到协助 下面是我配置寄存器: read tvp7002 parameter I2C (0x5d): 0x01 = 0x89 I2C (0x5d): 0x02 = 0x80 I2C (0x5d): 0x03 = 0xe0 I2C (0x5d): 0x04 = 0x00 I2C (0x5d): 0x05 = 0x06 I2C (0x5d): 0x06 = 0x10 I2C (0x5d): 0x07 = 0x2c I2C (0x5d): 0x0e = 0x36 I2C (0x5d): 0x0f = 0x2e I2C (0x5d): 0x10 = 0x58 I2C (0x5d): 0x11 = 0x40 I2C (0x5d): 0x12 = 0x01 I2C (0x5d): 0x13 = 0x00 I2C (0x5d): 0x14 = 0x95 //这个我觉得有异常,hs 和vs的同步脉冲极性相反,而且检测不到SOG activity,是否要改下同步方式 I2C (0x5d): 0x15 = 0x43 I2C (0x5d): 0x16 = 0x11 I2C (0x5d): 0x18 = 0x11 I2C (0x5d): 0x17 = 0x02 I2C (0x5d): 0x19 = 0x00 I2C (0x5d): 0x1a = 0xca I2C (0x5d): 0x1b = 0x77 I2C (0x5d): 0x1c = 0x07 I2C (0x5d): 0x1d = 0x00 I2C (0x5d): 0x1e = 0x10 I2C (0x5d): 0x1f = 0x10 I2C (0x5d): 0x20 = 0x10 I2C (0x5d): 0x21 = 0x22 I2C (0x5d): 0x22 = 0x00 I2C (0x5d): 0x23 = 0x37 I2C (0x5d): 0x24 = 0x31 I2C (0x5d): 0x25 = 0x14 I2C (0x5d): 0x26 = 0x80 I2C (0x5d): 0x27 = 0x2a I2C (0x5d): 0x28 = 0x53 I2C (0x5d): 0x2a = 0x87 I2C (0x5d): 0x2b = 0x00 I2C (0x5d): 0x2c = 0x80 I2C (0x5d): 0x2d = 0x00 I2C (0x5d): 0x2e = 0x80 I2C (0x5d): 0x2f = 0x8c I2C (0x5d): 0x31 = 0x18 I2C (0x5d): 0x35 = 0x00 I2C (0x5d): 0x36 = 0x00 I2C (0x5d): 0x37 = 0x5e I2C (0x5d): 0x38 = 0x24 I2C (0x5d): 0x39 = 0x61 I2C (0x5d): 0x3a = 0x00 I2C (0x5d): 0x3b = 0x07 I2C (0x5d): 0x3c = 0x03 I2C (0x5d): 0x3d = 0x06 I2C (0x5d): 0x3f = 0x00 I2C (0x5d): 0x40 = 0xda I2C (0x5d): 0x41 = 0x00 I2C (0x5d): 0x42 = 0x5e I2C (0x5d): 0x43 = 0x08 I2C (0x5d): 0x44 = 0x04 I2C (0x5d): 0x45 = 0x04 I2C (0x5d): 0x46 = 0x2d I2C (0x5d): 0x47 = 0x2d I2C (0x5d): 0x48 = 0x00 I2C (0x5d): 0x49 = 0x00 |
5 个讨论
你好,
我换了台电脑给tvp7002获取输出,屏幕可以显示满屏,分辨率都是1080p,都有根据“8637.tvp7002_THS8200_VGA_YPbPr_settings”配置,对比了寄存器如下图: 但是这俩台电脑都能正常满屏显示在 显示屏上,但经过tvp7002输出就是出现不满屏的现象(debug_tvp7002ok是能正常满屏,debug_tvp7002no是不满屏),对于了俩电脑显卡可以满屏的是HD Graphics 4400 ,不能满屏的是HD Graphics,已经有多台电脑出现不满屏现象, 不清楚这是tvp7002什么配置造成的,可以帮我解答下么? |
ctx1129 发表于 2019-3-5 17:57 我已找到原因是我根据tvp7002_VGA to YCbCr 422 es 文档里面配置的是HV 和SV都是P极性,我用1440x900有俩种配置,我试下情况真的一样的,我查看了1920x1080是没有这个HV为N极性,SV为P极性的配置,是不是说明tvp7002是不支持这种格式的视频源做输入?如果支持要如何去配置? |
只有小组成员才能发言,加入小组>>
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
531 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
977 浏览 1 评论
577 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
456 浏览 1 评论
993 浏览 0 评论
GMT+8, 2024-10-20 00:36 , Processed in 2.121390 second(s), Total 77, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
