扫一扫,分享给好友
有效区内自动调整后右边还有一小部分没有显示正常颜色,而是像灰色线条一样的边框,是什么原因??还有最左边怎么会多出一点点不一样的颜色??
module VGA_ROM(clk_50M,res_n,hs,vs,r,g,b); input clk_50M; //系统时钟50M input res_n; // 复位 output hs,vs; //行、场信号 output r,g,b; //r,g,b信号各一位 wire hs; wire vs; wire CLK_65M; pll_65 u1( .inclk0(clk_50M), .c0(CLK_65M), //1024*768,1344*806*60=65M ); reg [15:0]h_cnt; //行计数器 reg [15:0]v_cnt; //列计数器 always@(posedge CLK_65M or negedge res_n) begin if(!res_n) h_cnt<=16'd0; else if(h_cnt==16'd1344) h_cnt<=16'd0; else h_cnt<=h_cnt+1'b1; end always@(posedge CLK_65M or negedge res_n) begin if(!res_n) v_cnt<=16'd0; else if(v_cnt==16'd806) v_cnt<=16'd0; else if(h_cnt==16'd1344) v_cnt<=v_cnt+1'b1; end wire flag; //有效区域标识 assign flag=((v_cnt>=16'd35)&&(v_cnt<16'd803))&&((h_cnt>=16'd296)&&(h_cnt<16'd1320)); reg hs_r; reg vs_r; always@(posedge CLK_65M or negedge res_n) begin if(!res_n) hs_r<=1'b0; else if(h_cnt<16'd136) hs_r<=1'b0; //行同步负极性 else hs_r<=1'b1; end always@(posedge CLK_65M or negedge res_n) begin if(!res_n) vs_r<=1'b0; else if(v_cnt<16'd6) vs_r<=1'b0; //场同步负极性 else vs_r<=1'b1; end assign vs=vs_r; assign hs=hs_r; parameter Left=296, //行同步+行后消隐 PixelWidth=128, //行分8个块 PixelWidth1=192, //列分4个块 TOP=35; //场同步+场后消隐 reg [4:0]Xcoloradd; reg [2:0]Ycoloradd; always@(posedge CLK_65M or negedge res_n) //产生行地址(ROM水平地址) begin if(!res_n) Xcoloradd<=5'b00000; else if(h_cnt>=Left&&h_cnt end always@(posedge CLK_65M or negedge res_n) //列地址(ROM垂直地址) begin if(!res_n) Ycoloradd<=3'b000; else if(v_cnt>=TOP&&v_cnt end wire [4:0]coloradd; wire [2:0]color; assign coloradd=Xcoloradd|{Ycoloradd,2'b00}; //将水平地址和垂直地址合成ROM实际地址 rom_data u2( // 调用一个单口ROM .address(coloradd), .clock(CLK_65M), .q(color) ); assign {r,g,b}=(flag==1)?color:0; endmodule |
1个回答
同问~~~~~~~~~~~~~~
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
GMT+8, 2024-10-4 23:17 , Processed in 0.574181 second(s), Total 71, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
