电子发烧友论坛|
你好,
我的开发工具可以连接到CY5677 USB加密狗,但是当我按下“配对”按钮进入配对流(LE安全连接和JuffWork身份验证)时,它不能正常工作。 首先,CY5677发送配对请求,然后发送“配对响应”,然后“配对确认(从属)”。但是CY5677似乎没有收到“配对响应”,因为CY5677不发送“配对随机”和CysSARART弹出“AuthAgErrOrthAuthoCurtisTimeOutup”几秒钟后。 我发现奇怪的是,在我们发送“配对响应”之后,我的BLE嗅探器在下一个连接事件中显示了CY5677的“CRC错误包”。 然而,我试图把“SC点(安全连接)”0要求乐遗产配对,效果不错! 我不知道为什么发生和如何对cy5677乐安全连接正确。 谢谢! 以上来自于百度翻译 以下为原文 Hi, My development tool can connect to CY5677 u*** dongle, but it can't work correctly when I pressed "pair" button to enter pairing flow(LE Secure Connections and Justwork authentication). At first, CY5677 would send pairing request, then I send "pairing response" and followed by "pairing confirm(slave)". But CY5677 seems not to receive "pairing response" because CY5677 don't send "pairing random" and CySmsart pop up "AUTH_ERROR_AUTHENTICATION_TIMEOUT" a few seconds later. I found it strange that after we sent "pairing response", my ble sniffer showed "crc error packets" from CY5677 at the next connection event. However, I tried to set "SC bit(secure connection)" to 0 to request LE legacy pairing, it works fine! I don't know why happened with CY5677 and how to pair with LE Secure Connections properly. thanks! |
2个回答
你好,
请创建一个技术支持的案例,以便我们的工程师可以审查您的固件,并引导您通过这一点。 当做, -马杜 以上来自于百度翻译 以下为原文 Hi, Please create a Tech Support case so that our engineers can review your firmware and guide you through this. Regards, -Madhu |
你好,
我的设备充当LLE从角色,我的设备是广告,CY5677设备可以连接到我的设备,并开始使用配对按钮配对。 1。它开始发送发送SMP配对,我的设备发送SMP响应, 2。公钥被交换为主从和主从 三。Slave已经发送确认键,。 4。随机数也交换了。 5。我收到确认键错误匹配错误(AuthAythRoRealRealMyValueE.NothFug匹配)。 单元测试已经确认了我的密钥生成。 你能交叉检查一次,并引导我正确的道路。 谢谢。。。 以上来自于百度翻译 以下为原文 Hi, My device act as LE Slave role, My device is advertising and CY5677 device can connect to my device and start pairing using pair button. 1. It started the paring send smp pairing , my device sent smp response, 2. Public keys are exchanged master to slave and slave to master 3. Slave has sent confirm key,. 4. Random numbers also exchanged. 5. I received confirm key miss match error (AUTH_ERROR_CONFIRM_VALUE_NOT_MATCH). Unit testing has done for confirm key generation at my side. Can you cross check once and guide me right path. Thanks... |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 22:35 , Processed in 0.723352 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3018
