电子发烧友论坛|
有没有关于如何使用“CyByListTestExpTestType”功能的例子?我试图实现它,我不理解“测试数据的长度”是什么。那是“字节”吗?时间是几秒钟吗?我认为是时候了,但是CyByLyStistRealValTest'没有类似的时间成分(只有频率,发射器测试也有作为参数)。
以上来自于百度翻译 以下为原文 Is there any example on how to use the 'CyBle_StartTransmitterTest' function? I'm trying to implement it, and I don't understand what "length of test data" is. Is that 'bytes'? Is it 'time in seconds'? I thought it would be time, but the 'CyBle_StartReceiverTest' doesn't have a similar time component (only frequency, which the transmitter test also has as a parameter). |
4个回答
熊熊-谢谢。那到底是什么意思呢?是我的价值放在每个发射机的测试类型的字节数(零通七)?这是一个纯粹的字节数,将发射式直到字节计数过期了吗?例如,键入“一”发送一个字节的11110000 -如果我的字节数是“三十”它将30那些?(零式是一个位模式,因此有更多的数学,我猜)。谢谢!
以上来自于百度翻译 以下为原文 cutty bear - thanks. So what does that mean, exactly? Is the value I put in the byte count of each of the types of transmitter tests (ZERO thorugh SEVEN)? Is it a pure byte count that will keep transmitting that type until the byte count is expired? For example, type "ONE" transmits one byte of 11110000 - so if my byte count is "30" it will send 30 of those? (type ZERO is a 20-bit pattern, so there's more math there I guess). Thanks! |
首先,你去Psoc Creator。然后打开API文档。查一下你想知道的“CyByListStistTrimeTestTestTest.”这个词的长度是Unt8。
以上来自于百度翻译 以下为原文 First of all you go on Psoc Creator. Then you open API documentation. Look up what you wanted to know 'CyBle_StartTransimitterTest'. The word is uint8 in length. |
是的,我看过那些文件。这就是为什么我问这个问题开始,因为“测试数据的长度”有一个句子的描述,它没有给出关于长度是字节还是在“测试序列计数”的细节,或者它甚至是一个字节的事情与时间的事情(我的一个同事认为它在SeCo中是长的)。NDS“最初”。即使你认为长度意味着“数据”而不是“时间”,它没有给任何迹象显示它在一个重复的图案(虽然认为很容易),它不会告诉你它是否是完整的东西本身是重复,或是直到总字节发送。我曾在许多不同的技术,很多文档,我不得不说,迄今为止,公司有最糟糕的一个文档的API我读过。我的意思是,添加3段第一句说明这意味着什么的一个例子是多么难吗?
以上来自于百度翻译 以下为原文 Yes, I read that documentation. That's why I asked the question to begin with since "length of test data" had a one sentence description, and it doesn't give any details on whether length is in bytes or in "test sequence counts" or that it was even a byte thing vs. a time thing (one of my colleagues thought it was length in "seconds" initially). And even if you were to assume length meant "data" and not "time", it doesn't give any indication that it does it in a repeating pattern (though it's easy enough to assume that), and it doesn't tell you whether it's the full thing itself that is repeated, or just until the total bytes are sent. I've worked with a lot of documentation on a lot of different tech, and I have to say by far that Cypress has one of the worst documented APIs I've ever read. I mean, how hard is it to add a 3 sentence paragraph showing an example of what this means? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 03:58 , Processed in 0.680497 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7538
