电子发烧友论坛扫一扫,分享给好友
你好,
首先对不起我的英语,抱歉如果这是在一个错误的地方。 我尝试我的开发工具包CY3255(HTTP://www. CyPress)COM/?RID=38059)与CY3173板(HTTP://wwwyCysP.COM/)?摆脱= 38025),和我做3273板各层(4)和使用组件显示手动,拍小毛,现在我尝试使用PSoC MiniProg(我一起得到cy3275盒)不工作,不´柏程序员找不到设备,如果我试着写cy3275板做工精细, 需要帮助找到问题并解决它让董事会工作。当我插入12V电压LED和杰克做工精细,有12和4.89. cy3273 LM317上板后…谢谢大家 PSoC程序员 53.8 K 以上来自于百度翻译 以下为原文 Hi, First sorry my english and sorry if this is on a wrong place. I try work my DEV kit CY3275( http://www.cypress.com/?rID=38059 ) with board of CY3273( http://www.cypress.com/?rID=38025 ), and I make the board of 3273 with all layers (4) and use components indicated on manual of this, buyed on mouser, now I try use the PSoC MiniProg (I got it together CY3275 kit) and no work, the Cypress Programmer don´t find device, if I try write Cy3275 board work fine, Need help to find problem and fix it to make board work.. when I plug 12v on Jack led and voltage work fine, have 12 in and 4.89 after LM317 on Cy3273 board... thank you all
10个回答
您不能使用“循环”当板供电的外部。你可以从miniprog1主板力量然后你可以自由选择“重置”或“循环”
鲍勃 以上来自于百度翻译 以下为原文 You cannot use "Power Cycle" when the board is powered externally. You may power the board from MiniProg1 and then you are free to choose "Reset" or "Power Cycle" Bob |
谢谢,但仍然没有工作,
我尝试复位和电源和一些问题的设备 PSoC程序员 52.9 K 以上来自于百度翻译 以下为原文 Thank you, but still no working, I try with reset and powered and some problem of device
好的,所以我们必须一步一步地检查。
1)最新版本的软件(与Update Manager检查) 2)微型机器人工作吗?(通过ISSP访问原始柏林板检查) 如果所有的工作,错误将在你试图编程的板上。三检查每个连接 鲍勃 以上来自于百度翻译 以下为原文 Ok, so we have to check step-by-step. 1) Software on latest revision (check with update manager) 2) Does the Miniprog work? (Check by accessing an original cypress board via ISSP) if all works the error will be in the board you try to program. Triple-check every connection Bob |
好的,我会检查它现在,船上的原创,当我把电源板给我留言程序(板供电)和小板没有这个消息,可能有错,我将检查后的信息,非常感谢你。
以上来自于百度翻译 以下为原文 Ok, I will check it now, On board original, when I put power on board I get message on programer (board is powered) and on little board not have this message, maybe have any wrong, I will check and post informations, Thank you very much. |
嗨,我试着不能让它发挥作用,
我需要知道用ISSP MiniProg编写C8CPLC20的最小组件是什么 我尝试组装板只有32.768 kHz晶体和2 22PF Cap这个板由PSoC MiniProg供电, 我检查电压,5V VDD引脚芯片,检查地面和我连接电源复位SCL SDA连接器ISSP和writefail再次尝试 我没有把拉起来SCL SDA线和我不´T检查时钟32.768kHz晶体..我还需要通过ISSP MILPROG制作设备可写吗? 以上来自于百度翻译 以下为原文 Hi, I try and can´t make it work, I need know what is the minimal components to write C8CPLC20 with ISSP MiniProg I try assemble board only with 32.768khz Crystal and 2 22pf Cap of this Board powered by PSoC MiniProg, I check voltage and get 5v on Vdd pin on chip, Check ground and is OK I connect Power Ground Reset SCL SDA on connector of ISSP and try write Fail Again I not put pull up on scl sda lines and I don´t check clock on 32.768khz crystal.. I need any more to make device writable by ISSP MiniProg? |
一切听起来都很好。在编程中不需要使用石英钟。
你能给我们提供几张屏幕截图吗? 用MixPrim1设置功率前后 你是否有机会用不同的板测试MixPrime1,最好是一个柏树套件,看看它是否能够编程或被破坏。 鲍勃 以上来自于百度翻译 以下为原文 Everything sounds O.K. The quarz clock is not needed / used during programming. Can you provide us with a couple of screen-shots Before and after setting power with Miniprog1 Do you have got a chance to test the MiniProg1 with a different board, preferrably a Cypress-Kit to see if it is able to program or is broken. Bob |
你好,
现在我把问题解决了,我能写另一个设备吗?问题是CsSTAL 32.768 kHz焊盘上的连接SCL和SDA,但是现在的问题是CY8CPLC10不在设备数据库上。 编程终止 检测到的硅烷:“FF FF 11 11”不在数据库中 程序要求在10:5:59 功率在10:52:55μMIXPROD1/062000 B0A25 我尝试使用另一个CyPress CY8C9466,并完成写入过程。 以上来自于百度翻译 以下为原文 Hi, Now I fix the problem to write, can I write another device the problem is connect SCL and SDA on Cystal 32.768khz pads, But the problem now is CY8CPLC10 is not on device database I get error of this all time | Programming Terminated | Detected SiliconID: "FF FF 11 11" is not in database Program Requested at 10:52:59 | Power On at 10:52:55 | MINIProg1/0062000B0A25 I try with another Cypress CY8C29466 and work fine the write process, |
使用PSoC程序员,你做了固件更新吗?
微型机器人? 问候,Dana。 以上来自于百度翻译 以下为原文 Using PSOC Programmer did you do a firmware update on the Miniprog ? Regards, Dana. |
这和我一年前的问题相似。这是由于一些遗留下来的阿德安装设计师由于更新。
我建议你创建一个“MyCase'”。 在这个页面的顶部“支持和社区&技术支持-创建一个MyCase] 描述您的问题并留下您的电话号码,您将与OnLee会话进行修复(如果这是我假设的错误) 鲍勃 以上来自于百度翻译 以下为原文 Thie is similar to a problem I had a year ago. It was related to some leftovers from a de-installation of Designer due to an update. I suggest you to create a "MyCase". On top of this page "Support & Community -> Technical Support -> Create a MyCase" Describe your problem and leave your phone-number, you will be contacted with an onlie-session for repair (if it is the error I assume) Bob |
不使用PSoC程序员+ PSoC MiniProg,我烧在PSoC cy2373板固件有六跳线(或连接器)上…1功率miniprog电源(V)2 -复位- MiniProg Rst(R)3 -接地- int(连接中断)4 SCL -拉(与C miniprog)5 - 1 - 2(CLK时钟晶体32.768khz)6 SDA -拉(与D Miniprog)我用一个跳接4 5 5 6 CLK1和SCL - 2时钟- SDA
尝试燃烧和验证,并所有工作。 以上来自于百度翻译 以下为原文 No. using the PSoC programmer + PSoC MiniProg, I burn firmware on board of PSoC CY2373 Have 6 jumpers (or connectors) on board... 1 - Power - MiniProg Power (V) 2 - Reset - MiniProg Rst(R) 3 - GND - INT (connector to interruption) 4 - SCL - Pull UP (Connected to C Miniprog) 5 - CLK 1 - CLK 2 (Crystal 32.768khz) 6 - SDA - Pull UP (Connected to D Miniprog) I use one jump connecting 4 to 5 SCL - CLK1 and 5 to 6 CLK 2 - SDA try burn and verify and all work.. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 09:27 , Processed in 1.076326 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1120
