关于CY8C21534-24PVXI的P1(1)在我的CAPSENSE项目中的一个函数冲突,我使用了CY8C21534-24PVXI。我发现CY8C21534-24PVXI的P1(1)存在功能冲突:在该芯片的数据表中,P1(1)被描述为ISSP-SCLK的PIN,但是在PSoC设计器5软件中,P1(1)是唯一可用的反馈电阻器引脚。我怎样才能克服这种冲突呢?谢谢你的帮助。你的,中国
以上来自于百度翻译 以下为原文 a function conflict about the P1[1] of CY8C21534-24PVXI In one of my CapSense Project , I used a CY8C21534-24PVXI. I found there was a function conflict about the P1[1] of CY8C21534-24PVXI: In the Datasheet of this chip, P1[1] is described as a pin of ISSP-SCLK, but in PSoC Designer 5.0 software, P1[1] is the only feedback resistor pin available. How can I deel with this conflict? Thank you for your help. yours, tsmephisto,China |
3个回答
您可以使用P1(1)作为反馈电阻,同时也使用ISP。当您使用ISSP编程芯片时,反馈电阻器不会影响ISSP操作。请查看2014年关于ISSP的更多细节。只要ISSP引脚上的电阻器负载大于1K,就不会有问题。
以上来自于百度翻译 以下为原文 You can use P1[1] for the feedback resistor and at the same time use it for ISSP also. When you are programming the chip using the ISSP, the feedback resistor will not affect the ISSP operation. Check out AN2014 for more details about ISSP. As long as the resistor load on the ISSP pins is greater than 1K, there should be no problem. |
嗨,先生,我正在做一个关于4个按钮、1个滑块(8个扇区/段)和4个使用CY8C21534-24PVXI的LED的项目。我的按钮工作得很好(我可以点亮每个按钮上的LED),但是滑块工作不正常(只有5个扇区工作,休息不工作)。在这个项目中,我还尝试使用TX8SW用户模块使用多图。我不能使用P1 [ 5 ]的数据输出(I2C SDA)的目的,因为它是由反馈电阻器(10K)使用。然后,我尝试在P1〔1〕中连接10K电阻(由ISSP使用),并为I2C SDA配置P1〔5〕,但LED闪烁而无手指存在。我使用的是CyPress例子的C代码,下面附上。请帮助我解决这个问题。谢谢你乔尔
CY8C21534扣式滑块 4.1 K 以上来自于百度翻译 以下为原文 Hi Sir, I'm doing a project on Capsense with 4 buttons, 1 slider(8 sectors/segments) and 4 LEDs using CY8C21534-24PVXI. My buttons were working fine (I could lit the LEDs for each tapping on the buttons), but the sliders were not working properly (only 5 sectors were working; rest were not working). I'm also trying to use Multichart in this project using TX8SW user-module. I couldn't use P1[5] for the Data out (I2C SDA) purpose as it is used by feedback resistor (10K). Then, I tried connecting 10K resistor in P1[1] (used by ISSP), and configuring P1[5] for I2C SDA, but the LEDs were flashing without finger presence. I'm using C code from Cypress examples and it is attached below. Please help me out from this issues. Thanking you Joel |
对不起,在我以前的邮件中有一个错误,我使用的是2K(10K)的反馈电阻和10nF的CMOD。
乔尔 以上来自于百度翻译 以下为原文 Sorry, there's a mistake in my previous mail, I'm using feedback resistor of 2K(not 10K) and Cmod of 10nF. Joel |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-19 00:38 , Processed in 0.700796 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
