电子发烧友论坛|
我继续得到这个错误(见下文)。我使用一个自定义的主板布局与cy8c3244lti-130es2芯片。有人知道为什么会发生这样的事情吗?我有一个miniprog3 rev5编程器/调试器和板连接到相应的10针连接器匹配。请帮忙?
dbg.m0023:有一个错误,而编程设备:(PSoC Creator收到错误(100 -失败!SPC轮询超时。与芯片失去通信) 以上来自于百度翻译 以下为原文 I keep on getting this error (see below). I am using a custom board layout with a CY8C3244LTI-130ES2 chip. Does anyone know why this is happening or how to fix it? I have a MiniProg3 Rev5 programmer/debugger and the board is connected to the appropriate 10 pin connector to match. help please? dbg.M0023: There was an error while programming the device: (PSoC Creator received error (100 - FAILED! Timeout of SPC polling. Lost communication with chip.)) |
13个回答
你好,莫迪,
那时没有轻松的出路。 你必须从基础开始,验证你的电路。你可能想在一个已知的工作板上验证你的程序员。如果使用SWD,记住编程时钟必须是PSoC freq.的1/3或更少。 祝你好运 以上来自于百度翻译 以下为原文 Hi maudi, No easy way out then. You would have to start with the basics and verify your circuit. You may want to verify your programmer on a known working board. If you are using SWD remember the programming clock must 1/3 or less of the PSoC freq. Good luck |
请试试这个方法:
连接miniprog3连接到PC miniprog3 10针连接器目标打开程序员执行程序功能的SPC轮询错误执行任何其他程序的功能(校验,读,验证,执行程序编程或擦除。)成功的让我知道这可以为你工作了。 谢谢, 孟 以上来自于百度翻译 以下为原文 Please try this workaround:
Thanks, --Meng |
嗨,大家好,
我已经隔离了这个问题,并创建了一个应用程序来修复这个问题。 问题: -当WO锁存器未设置为0时,系统性能控制器(SPC)超时。 解决方案: 用全零编程WO锁存器。PSoCprogrammer没有这样做一旦设备被编程(避免过度编程的锁存器),所以我创建了一个Sal.net实用工具来修复这个。 它可以在这里下载: HTTP://www. NooToBoM.BIZ/DeLooSt/FixSPCimeTo.Zip 成功! 罗尔夫 FixSpTimeOut1.Zip 17.6 K 以上来自于百度翻译 以下为原文 Hi all, I've isolated the problem and created a application to fix this issue. Problem: - the System Performance Controller (SPC) times out when the WO latches aren't set to zero. Solution: - program the WO latches with all zeroes. PSoCprogrammer doesn't do this once the device is programmed (avoiding overprogramming the latches) so I created a smal .NET utility to fix this. It can be downloaded here: http://www.nooteboom.biz/downloads/FixSPCtimeout.zip Success! Rolf
更新:
现在在zip中使用PPycom包装器(必须解压缩到与.exe相同的文件夹)。还要确保安装了PSoCprogrammer。 请告诉我,如果这对你有用。 当做, 罗尔夫 FixSpTimeOut2.Zip 29 K 以上来自于百度翻译 以下为原文 Update: Now with PP_COM wrapper in the zip (has to be unzipped to the same folder as the .exe). Also make sure PSoCprogrammer is installed. Please let me know if this works for you. Regards, Rolf
我使用的是一个带有CY8C3244LTI—130ES2芯片的自定义电路板布局。我遇到了同样的问题。我安装了.NET实用程序FixSPcTimeOUT。但这对我没有帮助。
运行程序。选择选项:3.3V,复位,10PIN固定。 出现: NVL数据@ 0xF8从芯片读取:00 00×00 00 NVL数据OLE准备好了。 然后运行程序员,编程芯片。但还是要继续这个错误。 以上来自于百度翻译 以下为原文 I am using a custom board layout with a CY8C3244LTI-130ES2 chip too. I have the same problem. I install the .NET utility FixSPCtimeout. But it did not help me. Run the program. Choose options: 3.3v,Reset,10pin- FIX. appears: NVL DATA @ 0xF8 read from Chip:00 00 00 00 NVL DATA olready okay.. Then run the programmer, programming chip. But still keep on getting this error . |
你好,
我也有同样的问题。我尝试过.NET app,但是错误仍然存在。有人能解决这个问题吗?. 谢谢, -//稻田 以上来自于百度翻译 以下为原文 Hi, I have the same problem. I tried this .net app but the error still exists. Was anybody able to resolve this issue?. Thx, -//addy |
你有更多的信息吗?
你的PSoC程序员和MimPro的版本是什么? 零件以前已经被编程了吗? 硬件设置怎么样,是定制的PCB吗? 当做, 罗尔夫 以上来自于百度翻译 以下为原文 Do you have more info? What's the version of your PSoC Programmer and Miniprog? Was the part already programmed before? How's the hardware setup, is it a custom made PCB? Regards, Rolf |
ITOO也有类似的问题。
在最近几天从PSOC3 ES2到ES3。 我有一个进程,当它运行时,似乎破坏了PSoC3中关键的东西。 (它是Keil UVISION 4C项目的一个端口,用于标准8051)。 零件程序第一次是好的,但这之后是不可编程的。 当使用PSoC Creator重新编程时,IGET以下消息: dg.M033:选定的调试目标“未分配的CY8C3666 LTI-068”与项目选定的设备“CY8C3666 LTI-068 ES3”不兼容。 或 dg.M033:选定的调试目标“CY8C3666 LTI-068 ES1”与项目选定的设备“CY8C3666 LTI-068 ES3”不兼容。 使用独立PSoCProgrammer: 自动检测关闭: 节目在13:05:16完成,失败了!SPC轮询超时。与芯片失去沟通。擦除成功警告!&启用调试模式,这应该在生产之前从PSoC Creator关闭。在13:05:02×65536闪存字节设置到CY8C3666 LTI -068的设备 自动检测: 程序在13:11:15编程结束警告!&启用调试模式,这应该在生产之前从PSoC Creator关闭。错误!——>;| HEX文件是建立硅修订沙三段,但获得的设备修改一。|使用PSoC Creator产生适当的装置一个HEX文件。装置设置在13:11:14 cy8c3866lti-068 | 65536闪存字节 这已经发生在3个新设备上。 什么是corruoted或该如何“复位”psoccontents蚂蚁的想法呢? 以上来自于百度翻译 以下为原文 I too have a similar problem. I moved from PSOC3 ES2 to ES3 in the last few days. I have a progam which, when it runs, seems to corrupt something critical within the PSoC3. (It is a port of a Keil uVision4 C project meant for standard 8051s). The parts program fine the first time but after this they are un-reprogrammable. When I try to use PSoC Creator to reprogram, I get the following messages: dbg.M0033: The selected debug target 'CY8C3866LTI-068 UNASSIGNED' is not compatible with the project's selected device 'CY8C3866LTI-068 ES3'. or dbg.M0033: The selected debug target 'CY8C3866LTI-068 ES1' is not compatible with the project's selected device 'CY8C3866LTI-068 ES3'. Using standalone PSoC Programmer: Auto Detection off: Program Finished at 13:05:16 | FAILED! Timeout of SPC polling. Lost communication with chip. Erase Succeeded WARNING!---> Debug mode enabled, this should be turned off from PSoC Creator before production. Device set to CY8C3866LTI-068 at 13:05:02 | 65536 FLASH bytes Auto Detection on: Program Finished at 13:11:15 | | Programming Terminated WARNING!---> | Debug mode enabled, this should be turned off from PSoC Creator before production. ERROR!---> | The hex file was built for silicon revision ES3, but the acquired device is revision ES1. | Use PSoC Creator to generate a hex file for the proper device. Device set to CY8C3866LTI-068 at 13:11:14 | 65536 FLASH bytes This has happened on 3 new devices. Ant ideas on what is being corruoted or how I could "reset" PSoC contents ? |
请下载最新的PSoC程序员3.124,它解决了这个问题。
以上来自于百度翻译 以下为原文 Pls download the newest Psoc programmer 3.12.4, It fixed this issue. |
嗨,大家好,
今天,我遇到了同样的问题,问题如下: 节目在16:21:25完成,失败了!SPC轮询超时。与芯片失去沟通。flash启动程序的编写…擦除成功警告!&启用调试模式,这应该在生产之前从PSoC Creator关闭。在16:21:20×65536闪存字节设备系列中设置为CY8C3666 AXI-040的设备在16:21:20i处设置为CY8C38 xx:自动检测设备:CY8C3666 AXI-040 PSoC程序员版本为3.125.868 以上来自于百度翻译 以下为原文 Hi all, today,I have the same problem,the problem described as follows : Program Finished at 16:21:25 | | FAILED! Timeout of SPC polling. Lost communication with chip. | Programming of Flash Starting... | Erase Succeeded WARNING!---> | Debug mode enabled, this should be turned off from PSoC Creator before production. Device set to CY8C3866AXI-040 at 16:21:20 | 65536 FLASH bytes Device Family set to CY8C38xx at 16:21:20 | | Automatically Detected Device: CY8C3866AXI-040 the psoc programmer version is 3.12.5.868 |
你好,
你的样本中有多少给出了这个信息?是ES2还是ES3?你使用塞浦路斯提供的工具包还是你自己的开发工具包? 我希望你提交一个技术支持案例,这样我们就可以看到是否需要在芯片上做故障分析或类似的事情。 谢谢, 维韦克 以上来自于百度翻译 以下为原文 Hello, How many of your samples are giving this message? Is it ES2 or ES3? Are you using Cypress supplied kits or your own Development kit? I would like you to file a technical support case just so that we can see if there is a need to do failure analysis or something of that sort on this chip. Thanks, Vivek |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 03:24 , Processed in 0.975111 second(s), Total 98, Slave 80 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1211
