电子发烧友论坛|
我通过SPI接口在网络协处理器模式下使用BlueNRG-2。与我的设备建立连接后,如何判断远程设备是否支持数据长度扩展?
我已经尝试了ACI_GATT_EXCHANGE_CONFIG命令,但它会协商L2CAP的最大ATT_MTU大小,但响应事件不会告诉您任何有关链路层数据大小以及是否正在使用数据长度扩展的信息。有办法找出来吗? 以上来自于谷歌翻译 以下为原文 I'm using BlueNRG-2 in Network Coprocessor mode over the SPI interface. After establishing a connection with my device, how can I tell if the remote device supports Data Length Extension? I've experimented with the ACI_GATT_EXCHANGE_CONFIG command but that negotiates the max ATT_MTU size for L2CAP but the Response Event doesn't tell you anything about the Link Layer data size and if Data Length Extension is being used. Is there a way to find out? |
1个回答
我想到了。在我发布问题后不久,我注意到新的v2.1 FW与新文档一起发布。新版本具有用于协商更大的ATT_MTU和链路层PDU的新命令。
客户端的第一步是发送ACI_GATT_EXCHANGE_CONFIG命令,以便两端协商其最大MTU。我注意到如果MTU长度不需要,Android手机将无法打开DLE。 然后发送HCI_LE_SET_DATA_LENGTH命令。 4.1设备将拒绝该命令为无效,并且不会收到任何响应。有时候手机会打败你,要求你做DLE数据长度更改。无论哪种方式,您将获得包含DATA_LENGTH_CHANGE事件的HCI_LE_META_EVENT。该事件将包含新的LL数据包大小。 以上来自于谷歌翻译 以下为原文 I figured it out. Shortly after I posted my question, I noticed the new v2.1 FW was posted along with new documentation. The new release had new commands for negotiating larger ATT_MTU and Link Layer PDUs. First step for a client is to send an ACI_GATT_EXCHANGE_CONFIG command so that both ends negotiate their max MTU. I noticed Android phones will not turn on DLE if the MTU length does not require it. Then send an HCI_LE_SET_DATA_LENGTH command. A 4.1 device will reject the command as invalid and no response will be received. Sometimes a phone will beat you to it request a DLE data length change before you do. Either way, you will get an HCI_LE_META_EVENT containing a DATA_LENGTH_CHANGE event. The event will contain the new LL packet sizes. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 02:37 , Processed in 0.973441 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2828
