电子发烧友论坛|
嗨,我想绑定,实时接收传感器数据,并解除绑定-所有从我自己的应用程序是由Web应用程序驱动的。传感器控制仪表板似乎不能提供足够的灵活性来进行这些操作。我该怎么办呢?是否存在公开核心SCD功能的SDK或API?谢谢,Yani
以上来自于百度翻译 以下为原文 Hi, I would like to bind, receive the sensor data in real-time and unbind - all from my own application which is driven by a web application. Sensor Control Dashboard does not seem to provide enough flexibility to do these operations. How can I go about it? Is there an SDK or API that exposes core SCD functions? Thanks, -Yani |
3个回答
你好,Yani,SCD不过是一个应用程序,它是在.NET上通过USB通信到位于集线器内部的USB控制器的。该USB控制器然后与负责通过I2C线进行数据通信的控制器通信。您可以设计自己的应用程序,这些应用程序将由基于Web的应用程序驱动。SCD是一种显示实时数据传输的软件,如果您想在SCD的范围之外做任何新的事情,那么实现自己的应用程序总是明智的。
以上来自于百度翻译 以下为原文 Hello Yani, SCD is nothing but an application designed in .net communicating over USB to the USB controller sitting inside the HUB. This USB controller is then communicating with the controller responsible for data communication over I2C lines. You can design your own application which will be driven by your web based application. SCD is software which shows the real time data transfer and if you want to do anything new apart from the scope of SCD then it is always advisable to implement your own application. |
嗨,在我们最初的测试中,轮毂经常崩溃,一旦我们有超过四个传感器发送数据到轮毂每秒一秒的速率!根据该规范,集线器可以支持超过100个传感器输入,您是否遇到过这个问题?多谢,Pascal
以上来自于百度翻译 以下为原文 Hi, During our initial Tests, the HUB crashes often once we have more than four sensors sending data to the HUB at rates of every quarter of a second! According to the Spec. the HUB can support up more than 100 sensor inputs Have you experienced this problem? Many thanks, Pascal |
Pascal,我已经测试到10个节点,我从来没有遇到任何问题。你能告诉我轮毂撞车是什么意思吗?干杯,Sai
以上来自于百度翻译 以下为原文 Pascal, I have tested till 10 nodes , i never experience any problem. Can you please let me know what do you mean by HUB crash?? Cheers, Sai |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7255 浏览 0 评论
2482 浏览 1 评论
2176 浏览 1 评论
4037 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2082 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7758浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6314浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
752浏览 2评论
725浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8149浏览 2评论
/9
GMT+8, 2025-12-9 22:37 , Processed in 0.748694 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
390
