电子发烧友论坛|
我前一段时间切换到V3.65,我注意到清理和编译现在非常缓慢。在以前的版本中,在几秒钟内完成了对我的项目的完全编译。现在它只是爬行。错误似乎移到了另一个地方。之前,(我想)他们被列为模块被编译。现在,它编译完整的项目,然后列出错误。我使用的是XC16V1.31编译器。所以,有些配置需要更改,还是我错过的其他东西?我应该回到3.61吗?鲍勃-AE6RV
以上来自于百度翻译 以下为原文 I switched to V3.65 some time ago, and I've noticed that cleaning and compiling is now abysmally slow. In previous versions, a full compile on my project was done in just a few seconds. Now it just crawls. And errors seem to have been moved to a different place. Before, (I think) they were listed with the module being compiled. Now, it compiles the complete project and then lists the errors. I'm using the xc16 v1.31 compiler. So, did some configuration needs change, or something else that I missed? Should I go back to 3.61? Bob - AE6RV |
4个回答
当我用X 3.65进行XC16 1.25项目的清洁/建造时,大约需要3秒。在X之外建造它需要1.5秒。项目中有约3-4K的C线。
以上来自于百度翻译 以下为原文 When I do a clean/build of an XC16 1.25 project with X 3.65, it takes about 3 seconds. Building it outside of X takes 1.5 seconds. There are about 3-4K lines of C in the project. |
嗯,我只是把编译器放回XC16V1.30,现在只需几秒钟就可以重新编译了。我想知道为什么V1.31要慢得多?鲍勃-AE6RV
以上来自于百度翻译 以下为原文 Hmm. I just set the compiler back to XC16 V1.30, and now it's back to compiling in just a few seconds. I wonder why V1.31 is so much slower? Bob - AE6RV |
好的,谢谢。我试图回到1.25,但有一个bug,我必须围绕代码,并且周围的代码现在被删除。所以,我不知道。但至少有1.30的作品是预期的。
以上来自于百度翻译 以下为原文 OK, thanks. I tried going back to 1.25, but there was a bug that I had to code around, and that code-around is now removed. So, I dunno. But at least 1.30 works as expected. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 04:35 , Processed in 0.568053 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2177
