我用Debian Linux运行两台机器,并在MPLAB X 4.15上更新。在其中一个,这似乎工作,另一方面,MPLAB 4.15崩溃后不久开始。当从终端开始时,我得到下面的错误报告:程序“Java”接收到X窗口系统错误。这可能反映了程序中的一个错误。错误是“ReDrad BADION(无效图片参数)”。(详细说明:串行2338 ErrRoRyCad 143 RealestyCal码139 MyRoRyOffice代码7)(程序员注意:通常,X错误是异步报告的,也就是说,您将在收到错误后一段时间收到错误。若要调试程序,请使用-Salc命令行选项运行它以更改此行为。如果你在GDKYXXError()函数上中断,那么你可以从调试器中得到一个有意义的回溯。这个错误在更新Debian之后就消失了,但是情况更糟:MPLAB X 4.15的安装似乎毁了程序员的驱动程序。大多数时候,MPLAB X没有显示任何连接的PRO。语法。使用旧的MPLAB版本,然后切换回4.15帮助。然后我尝试编程而不将程序员连接到目标设备。在项目中选择的同一个CIPIT3,在项目配置中选择了MasaGePigIt3 Sn*,但看起来不是C。连接的PikIT3 SnA-无(VID 04D8,PID 900A)当前连接。您想使用这个皮卡3吗?我接受,然后我得到错误消息。目标电路可能需要比调试工具提供的更多的功率。外部电源可能是必要的。连接失败,或者只有“连接失败”,如果程序员不提供电源。当运行MPLAB x3.65或连接ICD 3时,我会得到相同的错误,附加的消息“端点2上的传输失败”。所以我不能工作。不再。
以上来自于百度翻译 以下为原文 I am running two machines with Debian Linux and updated on both to MPLAB X 4.15. On one of them, this seems to work, and on the other, MPLAB 4.15 crashes soon after starting. When starting from a terminal, I get the following error report: The program 'java' received an X Window System error. This probably reflects a bug in the program. The error was 'RenderBadPicture (invalid Picture parameter)'. (Details: serial 2338 error_code 143 request_code 139 minor_code 7) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the --sync command line option to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.) This error was gone after updating Debian - but it comes even worse: MPLAB X 4.15 installation seems to have ruined the programmers drivers. Most of the time, MPLAB X does not show any connected programmers. Using an older MPLAB version and then switching back to 4.15 helps. Then I try to program without connecting the programmer to a target device. With the same PICkit3 as selected in the project I get the message PICkit3 SN# was selected in the project configuration, but does not appear to be connected. PICkit3 SN#None (VID 04D8, PID 900A) is currently connected. Would you like to use this PICkit3 insted? I accept and then I get the error message The target circuit may require more power than the debug tool can provide. An external power supply might be necessary. Connection Failed. or only "Connection failed", if the programmer does not provide the power supply. I get the same errors when running MPLAB X 3.65 or when connecting an ICD 3, with the additional message "Transmission on endpoint 2 failed". So I can't work anymore. |
3个回答
我在另一台Debian Linux机器上查看了一个未更新的MPLAB X 3.65:它不是我假设的驱动错误,它是错误的程序员固件。在这里,在没有更新的MPLAB X 3.65的机器上,我得到了“未知固件类型”的消息,MPLAB X重新编程了PICTIT3或ICD 3的固件,然后所有都如期运行。为什么当MPLAX 4.15的机器启动时,即使我启动一个更老的MPLAB X,为什么使用错误的固件?
以上来自于百度翻译 以下为原文 I checked on another Debian Linux machine with a non updated MPLAB X 3.65: It is not a driver fault as I assumed, it is wrong programmer firmware. Here, on this machine with non updated MPLAB X 3.65, I get the message "Unknown Firmware type", MPLAB X reprograms the firmware of PICkit3 or ICD 3 and then all is running as expected. Why do those machines with MPLAB X 4.15 use the wrong firmware even when I start an older MPLAB X? |
我卸载了所有的MPLAB并重新安装了MPLAB 3.3.5。第一次看,一切似乎都还好——但是编程仍然不起作用:-当解锁或插入程序员的USB连接器时,这在项目属性窗口中没有立即显示,只有在关闭和重新打开之后才显示出来。项目属性窗口-程序员不显示序列号。-当尝试编程时,一个无意义的消息弹出:选择了SKIN Sn*…但是…PcIt SnSy-No当前没有连接…-更改处理器类型不起作用:然后“连接失败”错误弹出,程序员无法在此计算机上使用!
以上来自于百度翻译 以下为原文 I uninstalled all MPLABs and reinstalled MPLAB X 3.65. - When unplugging or plugging the USB connector of a programmer, this is not shown immediately in a project properties window, only after closing and reopening the project properties window. - The programmers show no serial numbers. - When trying to program, a nonsense message pops up: PICkit SN# was selected ... but ... PICkit SN#None is currently connected... - Changing the processor type does not work: then a 'Connection Failed' error pops up and the programmer stays unusable on this computer! |
我做了第二次卸载/重新安装MPLAB X 3.65:最后,我能够使用MPLAB X再次…不知道为什么第一次跑不起作用。
以上来自于百度翻译 以下为原文 I did a second uninstall / reinstall of MPLAB X 3.65: Finally I am able to use MPLAB X again... no idea, why the first run did not work. |
只有小组成员才能发言,加入小组>>
5242 浏览 9 评论
2031 浏览 8 评论
1955 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3207 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2256 浏览 5 评论
778浏览 1评论
666浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
595浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
677浏览 0评论
576浏览 0评论
GMT+8, 2024-12-23 11:40 , Processed in 1.115411 second(s), Total 53, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
