电子发烧友论坛|
你好。塞浦路斯是否为CY7C637芯片提供通用驱动程序,用USB收发器发送和接收数据?如果没有,有明确的文件来开发这个吗?多谢!
以上来自于百度翻译 以下为原文 Hello. Does Cyprus provide generic drivers for the Cy7C637 chip for sending and receiving data with a USB transceiver? If not, is there clear documentation available to develop this? Many thanks! |
4个回答
嗨,多谢,我想你是在错误的论坛上发表的。CY7C637*设备是低速有线USB外围设备MCU。
以上来自于百度翻译 以下为原文 Hi dorsher, I think you've posted in the wrong forum. The CY7C637* devices are low-speed wired USB peripheral MCUs. |
你好,小黄:你可能是对的,虽然我们使用的cy7c637用于USB无线收发器。
以上来自于百度翻译 以下为原文 Hello syf: You are probably right, although our use of the CY7C637 is used in a USB wireless transceiver. |
我明白你的意思。最好的办法是使用HID类驱动程序,这些驱动程序内置于大多数操作系统中。顺便说一句,如果这是一个新的发展,我建议你使用新的CY7C638 XX系列设备(安可二家庭)。如果你使用它与无线USB收音机的HID应用程序,那么你最好的办法是检查CY4636键盘鼠标参考设计工具包。它展示了如何在大多数操作系统中配置EnCORE II MCU作为USB HID设备枚举本地支持。你能告诉我你的申请是什么吗?我可能能够更好地指导柏树技术和产品如何满足您的需求。
以上来自于百度翻译 以下为原文 I see what you mean. Your best bet is to use the HID class driver that is built into most operating systems. BTW, if this is a new development, I suggest that you use the newer CY7C638xx series of devices (the enCoRe II family). If you are using it in conjunction with a WirelessUSB radio for HID applications, then your best bet is to check out the CY4636 Keyboard Mouse Reference Design Kit. It shows you how to configure the enCoRe II MCU to enumerate as a USB HID device for native support in most operating systems. Can you tell me what your application is? I may be able to provide better guidance on what Cypress technologies and products would suit your needs. |
你好,Syf:这是为已经存在的市售产品创建自定义驱动程序。它是针对X10的无线收发器,CM19A模型。不幸的是,我们不能使用不同的芯片或重新编程。设备本身并不是一个HID设备,所以我不认为Windows的HID类驱动程序能够从它发送/接收数据。希望我没有违反论坛的使用,但我必须问:我能补偿你通过电话指导我的解决方案(美国居民)。多谢!
以上来自于百度翻译 以下为原文 Hello Syf: This is for creating a custom driver for an already existing commercially available product. It is for X10's wireless transceiver, model CM19A. Unfortunately, we cannot use a different chip or reprogram it as a result. The device itself is not a HID device, so I don't think that the HID class drivers for Windows will be able to send/receive data from it. Hopefully I am not violating use of the forum, but I have to ask: Can I compensate you to guide me via the phone for a solution (US resident). Many thanks! |
只有小组成员才能发言,加入小组>>
787个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7288 浏览 0 评论
2484 浏览 1 评论
2178 浏览 1 评论
4041 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2084 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7779浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6337浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
755浏览 2评论
729浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8186浏览 2评论
/9
GMT+8, 2025-12-11 01:54 , Processed in 0.591949 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3386
