电子发烧友论坛|
我写了个程序,想让DSP CE1脚拉低。
程序如下: for(;;) [ souraddr = (unsigned int *)0x403c00; *souraddr=0xff; delay(); delay(); souraddr = (unsigned int *)0x403800; *souraddr=0; delay(); delay(); ] 可是CE1脚一直是高。是不是EMIF没配置好?如何配置?谢谢! |
4 个讨论
TMS320VC5509 CPLD /*SDRAM的EMIF设置*/ EMIF_Config emiffig = [ 0x221, //EGCR : the MEMFREQ = 00,the clock for the memory is equal to cpu frequence // the WPE = 0 ,forbiden the writing posting when we debug the EMIF // the MEMCEN = 1,the memory clock is reflected on the CLKMEM pin // the NOHOLD = 1,HOLD requests are not recognized by the EMIF 0xFFFF, //EMI_RST: any write to this register resets the EMIF state machine 0x3FFF, //CE0_1: CE0 space control register 1 // MTYPE = 011,Synchronous DRAM(SDRAM),16-bit data bus width 0xFFFF, //CE0_2: CE0 space control register 2 0x00FF, //CE0_3: CE0 space control register 3 // TIMEOUT = 0xFF; 0x1FFF, //CE1_1: CE0 space control register 1 // Asynchronous, 16Bit 0xFFFF, //CE1_2: CE0 space control register 2 0x00FF, //CE1_3: CE0 space control register 3 0x1FFF, //CE2_1: CE0 space control register 1 // Asynchronous, 16Bit 0xFFFF, //CE2_2: CE0 space control register 2 0x00FF, //CE2_3: CE0 space control register 3 0x1FFF, //CE3_1: CE0 space control register 1 // Asynchronous, 16Bit 0xFFFF, //CE3_2: CE0 space control register 2 0x00FF, //CE3_3: CE0 space control register 3 0x2911, //SDC1: SDRAM control register 1 // TRC = 8 // SDSIZE = 0;SDWID = 0 // RFEN = 1 // TRCD = 2 // TRP = 2 0x0410, //SDPER : SDRAM period register // 7ns *4096 0x07FF, //SDINIT: SDRAM initialization register // any write to this register to init the all CE spaces, // do it after hardware reset or power up the C55x device 0x0131 //SDC2: SDRAM control register 2 // SDACC = 0; // TMRD = 01; // TRAS = 0101; // TACTV2ACTV = 0001; ]; |
只有小组成员才能发言,加入小组>>
586 浏览 0 评论
1644 浏览 0 评论
2082 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1534 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1375 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1787浏览 29评论
2816浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1746浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1657浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1676浏览 13评论
/9
GMT+8, 2025-12-11 08:26 , Processed in 0.776647 second(s), Total 47, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3285
