电子发烧友论坛|
我的N5242A固件为09.22.02,硬盘为S.08.24。
硬盘被更换了,现在我无法通过SICL-LAN与之通信。 我已经尝试了附件中的内容,我尝试了以下内容,但仍然无法让NI MAX识别PNA-X。 即使按照说明操作,我的PNA-X(N5242A)也无法通过LAN连接SICL。 我该如何解决? 一些早期的PNA-X设备配置错误(2007年11月之前发布)。要解决此问题,请执行C: Program Files Agilent IO Libraries Suite bin iocfg32.exe。 忽略任何USB-GPIB警告。 在Configured Interfaces下,找到SICL名称为hpib7的项目并将其删除。 在“可用接口类型”下,找到“内部仪器”界面,然后单击“配置” 接受默认值; 单击确定。 在PNA应用程序上,单击Utility,System,Configure,SICL / GPIB / SCPI并禁用SICL自动启动。 完全退出PNA-X应用程序。 重新启动PNA-X应用程序,然后重新启用SICL自动启动。 还有其他建议吗? 谢谢! 以上来自于谷歌翻译 以下为原文 I have an N5242A with firmware 09.22.02 and hard drive S.08.24. The hard drive was replaced and now I cannot communicate with it through SICL-LAN. I have tried what is in the attached file and I have tried the following and I still cannot get NI MAX to recognize the PNA-X. My PNA-X (N5242A) cannot connect via SICL over LAN even after following your instructions. How do I fix this? Some early PNA-X unit were misconfigured (those shipped before Nov 2007.) To fix this, execute C:Program FilesAgilentIO Libraries Suitebiniocfg32.exe. Ignore any USB-GPIB warning. Under Configured Interfaces, find the item with the SICL name of hpib7 and remove it. Under Available Interface Type, find the Internal Instrument interface and click on Configure. Accept the defaults; click OK. On the PNA application, click on Utility, System, Configure, SICL/GPIB/SCPI and disable the SICL Automatic Startup. Exit the PNA-X application entirely. Re launch the PNA-X app and then re-enable the SICL Automatic Startup. Any other suggestions? Thanks! 附件 |
1个回答
对于这些类型的问题(新的硬盘驱动器问题,连接问题),您可以联系我们的好支持人员:christopher_rich@keysight.com
以上来自于谷歌翻译 以下为原文 for these type issues (new hard-drive issues, connectivity issues), you can contact our good support guy: christopher_rich@keysight.com |
只有小组成员才能发言,加入小组>>
250 浏览 0 评论
1863 浏览 0 评论
2753 浏览 1 评论
2656 浏览 1 评论
2477 浏览 5 评论
1863浏览 0评论
431浏览 0评论
260浏览 0评论
/9
GMT+8, 2025-12-12 05:43 , Processed in 0.712441 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2038
