扫一扫,分享给好友
大家好,
我想知道通过USB同时传输Delsig ADC的连续数字输出数据的可能方法。如果答案是使用DMA,我找不到他们的TD和频道的广告,所以我可以用它作为PiFiell到PifelAL转移ADC->USB。 提前感谢 最大损伤 以上来自于百度翻译 以下为原文 Hello Everybody , I want toKnow the possible means to transfer continuous Digital output data of the DelSig ADC through the USB simultanuously. and if the answer is using DMA i cant find the Adresses for their TD and channel so i can use it as Periferal to Periferal transfer ADC->USB. Thanks in advance Maxdamage |
13个回答
在创建者的开始页面,你可以搜索例子。有一个名为USPFSX音频,它使用DMA来传输数据。这可能有助于回答你的问题。
鲍勃 以上来自于百度翻译 以下为原文 On Creator's start page you can search for examples. There is one named USBFS_AUDIO which uses DMA to transfer the data. This will probably help answering your questions. Bob |
看一下项目102,使用PSoC的USB音频,但我认为USPFSX音频-不是一个好主意- ADC数据失真窗口(音量控制和内置过滤器)。
也许使用一个高速的UBFS示例项目DMA自动模式,但在仿真UART模式中是现实的吗???? 以上来自于百度翻译 以下为原文 and take a look at Project#102 – USB Audio using the PSoC But I think USBFS_AUDIO - not a good idea - ADC data distorted Windows (volume control and built-in filter). maybe Is it realistic to use a high speed USBFS example project DMA Auto Mode, but in emulation UART mode ??? |
这将讨论ADC(以及其他注意事项)的地址,在哪里找到它们。
HTTP://www. CyPress?COM/?RID=44335 AN6102 问候,Dana。 以上来自于百度翻译 以下为原文 This discusses addresses, where to find them, for ADC (and other considerations) - http://www.cypress.com/?rID=44335 AN61102 Regards, Dana. |
你好PSoC大师,谢谢你的回复。
我还有另一个问题,我从这里下载的大部分项目都不起作用,我认为它们与我的创建者版本不兼容,你有什么建议?(附上屏幕截图)。 另一件事AN6102不包含USB外围设备的扩展地址。我已经知道,不可能直接通过USB传输ADC输出,它必须先通过SRAM,这是真的吗? UBS1.PNG 194.3 K 以上来自于百度翻译 以下为原文 Hello PSoC masters, thanks for reply. I have another problem most of the projects i download it from here won't work i think they are not compatible with my version of the creator what do you propose?(screen shot for it is attached). Another thing AN61102 doesn't contain the distination address of the USB periferal . I've read that it isn't possible to transfer ADC output directly throuth the USB it must go through the SRAM first is that true?
是的,您使用的是创建者2,而最新的版本是创建者3。您可以从CyPress网站下载最新的安装,它将与旧的2共存。从这里下载。
鲍勃 以上来自于百度翻译 以下为原文 Yes, you are using Creator 2.0 while the latest version is Creator 3.0. You can download latest from Cypress's website and install, it will be co-existent with the older 2.0. Download from here secure.cypress.com/psoccreator/ Bob |
我试图做一个简单的项目ADC->USB(UART)。
但是我不知道如何使用DMA来处理UBUTART。 UBS16BITYADC.CYWRK.SARVEVE01.ZIP 2.1兆字节 以上来自于百度翻译 以下为原文 I tried to make a simple project ADC-> USB (UART). But I do not know how to use DMA for USBUART |
这可能有帮助
HTTP://www. CyPress?COM/?RID=39553 AN5637 问候,Dana。 以上来自于百度翻译 以下为原文 This might help - http://www.cypress.com/?rID=39553 AN56377 Regards, Dana. |
大家好,
在我的人生中第一次我想当我阅读更多的时候我变得更加困惑!! 我已经阅读了由Dana提出的应用程序注释,它是AN56337。它非常全面和复杂,但它不是信息丰富的。我认为与我不想做的最相似的项目是Project 3:用DMA自动内存MGMT增加USB吞吐量。我试图编译这个项目,这将有助于了解他们正在做什么,帮助我解决错误。 我想知道如何在USB接口的模切模式中填充SRAM部分。 USB DMA示例 171.1 K 以上来自于百度翻译 以下为原文 Hello people, For the first time in my life i think when i read more i became more confused !! i've read the application notes suggesed by Dana which is AN56377. its very comprehensive and complex but it isn't that informative. i think the most similar project to what i wan't to do is Project 3: Increasing USB Throughput with DMA Automatic Memory Mgmt. I am trying to compile this project which will facilitate understanding what they are trying to do help me solve the error. I want to know how can i fill the SRAM part in the cut through mode of the USB with ADC output.
图片没有多大用处,最好是上传完整的项目,因为它包含了所有的设置。使用创建者& gt;文件-gt;创建工作区包并上传生成的存档(不使用Chrome,将不工作)
鲍勃 以上来自于百度翻译 以下为原文 A picture does not help much, best is always to upload the complete project since it contains all your settings. Use Creator -> File -> Create Workspace Bundle and upload the resulting archive (do NOT use chrome, will not work) Bob |
在我安装了创建者的新版本之后,我以前的大多数项目似乎都不能正常工作!!
以上来自于百度翻译 以下为原文 After I install the new version of the creator most of my previous projects seem to not work appropriately!! |
是的,引导代码改变了,库移到纳米库,看看
在创建者文档和谷歌“PSoC创建者”中的版本注释 “3个问题”,你会看到这些问题是如何处理的。 问候,Dana。 以上来自于百度翻译 以下为原文 Yes, boot code changed, libraries moved to nano libraries, look at release notes in Creator Documentation and google "psoc creator 3.0 problems" and you will see where these issues were handled. Regards, Dana. |
大家好,
我试图看到鲍伯(USPFSX音频)指出的一个示例项目,IAM想知道它是否有与它相关联的应用笔记? 定义nUnthBuf(10u)*定义TurnSe大小(32 U) 为什么要使用10个TD和32个事务位? 为什么要使用无符号数字?我们通常用赤身***的数字。 以上来自于百度翻译 以下为原文 Hello guys, I am trying to perceive one of the example projects that is pointed out by Bob (USBFS_AUDIO) and Iam wondering if it has app note associated with it ? #define NUM_BUF (10u) #define TRANS_SIZE (32u) Why to use 10 TD and 32 Transaction bits? Why to use unsigned numbers ? we normally use the number naked. |
你见过负缓冲区计数吗?这是一个无符号的数字,因此它是这样表达的。
这是根据MISRA-C标准E.WiKiTo.Org/Wik/MasRAYC来完成的。 鲍勃 以上来自于百度翻译 以下为原文 Have you ever seen a negative buffer count? This IS an unsigned number, and so it is expressed as such. That is done according to the MISRA-C standard en.wikipedia.org/wiki/MISRA_C Bob |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 06:12 , Processed in 1.189509 second(s), Total 66, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2109
