嗨,我正在尝试使用我们的STM3210B评估套件(shinano MB459),但我有一些问题使用它。当我启动ST电机控制工作台时:
- 选择示例项目STM3210B-Eval-MB459-Shinano - 检查电机,微型(stm32F103中)的值 - 检查引脚分配(usart1 TX A9 / RX A10) - 检查驱动器管理/用户界面附加组件中的lcd和Serial - 选择输出文件夹(C: Program Files(x86) STMicroelectronics FOC SDK STM32 PMSM FOC LIBv4.2 Web SystemDriveParams) - 生成代码 - 使用Iar启动项目(C: Program Files(x86) STMicroelectronics FOC SDK STM32 PMSM FOC LIBv4.2 Web Project EWARM STM32F10x_Workspace) - 配置Iar以构建STM3210B-EVAL - 项目构建好 - 将应用加载到卡中 - >好 - 重置卡 问题是液晶屏幕上没有任何内容,ST电机控制工作台的串口通讯不起作用! 你对这个问题有所了解吗? 编辑 : 问题解决后,需要配置使用带光选项的LCD(不满)。 现在正在努力 以上来自于谷歌翻译 以下为原文 Hi i'm trying to work with our STM3210B eval kit (shinano MB459) but i have some problem to use it. When i launch ST Motor Control Workbench : - Choose example project STM3210B-Eval-MB459-Shinano - Check the values of motor, micro (stm32F103 Medium) - Check pin assignment (usart1 TX A9 / RX A10) - check lcd and Serial in drive management / user Interface Add-on - choose the output folder (C:Program Files (x86)STMicroelectronicsFOC SDKSTM32 PMSM FOC LIBv4.2WebSystemDriveParams) - generate the code - launch the project with Iar (C:Program Files (x86)STMicroelectronicsFOC SDKSTM32 PMSM FOC LIBv4.2WebProjectEWARMSTM32F10x_Workspace) - configure Iar to build STM3210B-EVAL - project build ok - load the app in the card --> ok - reset the card The problem is that nothing appear on the lcd screen and serial com with ST Motor Control Workbench not work ! Do you have an idea of the problem please ? edit : Problem resolve, need to configure the use of LCD with light option (not full). Now is working |
1个回答
再见
我再给你一些提示。 LCD的完整版本需要以与电机控制部件分开的方式进行编程。所有这些都在UM中进行了解释,因此如果您想要享受完整的液晶显示屏,您可以看看。 如果您没有对LCD进行编程并启用它,则固件将停止,LCD和串行通信将停止。如果您不想编写FULL LCD代码,则另一个选项是在WB中禁用它并仅使用串行通信。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao I give to you one more hints. The full version of the LCD needs to be programmed in a separate way respect the motor control part. All of this is explained in the UM so if you want to enjoy the full LCD you can take a look. If you didn't program the LCD and you enable it the firmware will stop and LCD and serial communication is stopped. Another option if you don't want to program the FULL LCD code is to disable it in the WB and use only the serial communication. Ciao Gigi |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2451 浏览 1 评论
3158 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1725 浏览 1 评论
3543 浏览 6 评论
5903 浏览 21 评论
883浏览 4评论
1261浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
527浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1244浏览 3评论
1298浏览 3评论
GMT+8, 2024-9-28 21:35 , Processed in 1.043245 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
