电子发烧友论坛|
你好,
我正在使用FX3超高速探险家工具包,用于Linux。 我使用的是Linux软件的CyUSB套件。 在安装“CysBuLinux”应用程序之后,我检查了设备列表。 并选择下载一个固件映像到RAM。 返回到描述符选项卡,我不能显示设备的详细信息(设备列表,EXOTPOON/IN…等等)。 所以,我不能发送数据。 错误信息如下: 我想知道安装Linux应用程序是否有问题,或者我遇到了什么问题。 以上来自于百度翻译 以下为原文 Hi, I'm working with the FX3 SuperSpeed Explorer kit for linux. I use the CyUSB Suite for Linux software. After installing the 'cyu***_linux' application, I checked the device list. and select to download a firmware image to RAM. Going back to the Descriptors tab, I could not show the details of the device (List of device, Endpoint OUT/IN...etc,.), So, I couldn't send data. The error message is as follows : I was wondering if there was a problem installing the application for Linux, or what problem I was having. |
6个回答
你好,
从您的描述中,您正在尝试将固件映像下载到FX3超高速探索者工具包。从快照来看,我认为你需要做以下的事情来解决这个问题。 1。请检查一下你的FX3SDKKLinux是否是最新的一个(你可以下载最新的一个链接:EZ-USB FX3软件开发工具包CyPress半导体)。从“成功下载”对话框看来,固件映像已经从启动按钮成功下载,点击单击HANDRID-ONYPB4YSTARTJY,然后API FX3Y-UBBoToSo下载有正确的返回。你能用LSSUB检查一下你是否可以在下载固件映像后找到相关设备。 2。从应用程序打印“失败的STAT文件N错误:无效固件文件格式”,检查源代码,我们可以打印额外的文件名。从没有文件名的控制台打印,似乎有一些不匹配。请在Linux中使用TIPS 1最新SDK。 谢谢。 最好的问候 曾伟 以上来自于百度翻译 以下为原文 Hi, From your description, You are trying to download firmware image to the FX3 SuperSpeed Explorer kit. From the snapshot, I think you need to do the following things to locate the issue. 1. Could you please check if your fx3_sdk_linux is the latest one(You could download the lastest one from link: EZ-USB FX3 Software Development Kit | Cypress Semiconductor ). From the "Succesfully downloaded" dialog, seems the firmware image has been downloaded succesfully from start button click hanlder-on_pb4_start_clicked, then API fx3_u***boot_download has correct return. Could you check with lsu*** to see if you could find the relevant devices after you download the firmware image. 2. From application prints "Failed to stat filen Error: Invalid firmware file format", check from the source code, we could prints additional files name. From your console prints without filesname, it seems some mismatch. Please check with the tips 1 lastest SDK in linux. Thanks. Best Regards Zeng Wei |
首先,谢谢你的回复。
我安装了最新版本的FX3YSDKJLinux,但我不知道什么是“开始按钮”点击“HaldDel-OnthPb4SARTIGHEL”点击“你刚才说的”。按钮在哪里? 关于错误代码,我将再次检查文件名。 谢谢你的小费。 以上来自于百度翻译 以下为原文 First, thank you for your reply. I installed the latest version of fx3_sdk_linux, but I do not know what 'start button click hanlder-on_pb4_start_clicked' you were talking about. Where is the button? Regarding the error code, I will check the file name again. Thanks for the tip. |
你好,
您可以在文件GuiaSrc/MeN.CPP中搜索空控制中心::ONYPB4ARSTARKCLICKEDE()。这个“开始”按钮单击“处理程序”。 你可以用QT4创建者打开QT项目。然后,您将找到名为PB4YSTART的启动按钮。 谢谢。 以上来自于百度翻译 以下为原文 Hi, You could search void ControlCenter::on_pb4_start_clicked() in file gui_src/main.cpp. This the start button click handler. You could open the QT project with qt4-creator. Then you will find the start button named pb4_start. Thanks. |
嗨,你能告诉我如何安装CysBuLinux吗?我试了很多次,都失败了!谢谢!
以上来自于百度翻译 以下为原文 Hi, could you tell me how to install cyu***_linux? I tried many times, all failed! Thanks! |
你好,清水港,
请阅读CysBuLinux包中的“ReMe.txt”文件。 如果你在某个时候停留在安装上,请友好地发布查询。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Qingshui Kong, Please read the 'Readme.txt' file in the cyu***_linux package. In case you are stuck at installation at some point, kindly, post the query. Best regards, Srinath S |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 23:53 , Processed in 1.021815 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8130
