扫一扫,分享给好友
所以我们刚刚买了PSoC FrimtTouter 3,而驱动站并没有把它捡起来。
DS版本-02.27.1.00 PSoC Creator版本-3.120.827 固件版本FRCYIO.V2.HEX 我们所做的就是连接PSoC,运行CyPress程序所需的驱动程序更新,并用上面的固件闪亮。然而,在USB连接时,驱动站并没有拾取PSoC。有什么想法吗? 以上来自于百度翻译 以下为原文 So we just bought the PSoC FirstTouch 3, and the driver station isn't picking it up. DS version - 02.27.11.00 PSoC Creator version - 3.12.0.827 Firmware version - FRC_IO.v2.hex All we did was hook up the PSoC, ran the driver station update for the cypress programs needed, and flashed it with the above firmware. However, the driver station isn't picking up the PSoC when connected via USB. Any ideas? |
3个回答
我们正在调查这个问题。NI工程师其实写固件,所以我们需要向他请教这个问题。
当做, 帕特里克凯恩 以上来自于百度翻译 以下为原文 We are looking into this. A SW engineer from NI actually wrote the firmware so we need to consult with him on this issue. Regards, Patrick Kane |
我有一个很难让我的FTK出现在驱动站和。我用的是相同的DS和固件版本,但我使用不同的程序版本(PSoC程序员3.12)。奇怪的是,一个程序员的版本(3.13.3)甚至不会在FTK板获取的PSoC器件,甚至不会编程。
以上来自于百度翻译 以下为原文 I am having a hard time getting my FTK to show up on the driver station as well. I am using the same DS and Firmware versions, but am using a different programmer version (PSoC Programmer 3.12). The strange thing is that a later version of the programmer (3.13.3) will not even acquire the PSoC device on the FTK board and will not even program it. |
您有PSoC程序员的正确版本(3.120.827)
确保CyMyPrime3Service服务正在运行。 检查设备管理器并确保设备显示为“FTK3(3.4.1.20)”。 -乔 以上来自于百度翻译 以下为原文 You have the correct version of the PSoC Programmer (3.12.0.827) Make sure that the CyMiniProg3Service service is running Check the Device Manager and make sure that the device is showing up as "FTK3 (3.4.1.20)" -Joe |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1908 浏览 1 评论
1659 浏览 1 评论
3415 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1578 浏览 6 评论
1386 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
197浏览 2评论
190浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
332浏览 2评论
357浏览 1评论
70浏览 1评论
GMT+8, 2024-5-2 21:45 , Processed in 0.494145 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
