电子发烧友论坛|
嗨,
我想尝试色度重采样器IP。 所以我获得了硬件评估许可证,以便在我的主板上进行测试。 但是,在比特流生成过程中,我得到了: [Common 17-69]命令失败:此设计包含一个或多个不允许生成比特流的单元:sdi_yuv_to_video_rgb_0 / resampler / U0(v_cresample_0__v_cresample)如果添加了新的IP Core许可证,则需要选择新的许可证 在比特流生成之前,需要通过重置和重新生成IP输出产品来更新当前网表。 我试图重置/生成输出产品,但没有效果。 我附上IP接口的屏幕截图,并报告IP状态。 如果有人可以帮助我...... 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I want to try the chroma resampler IP. So i get a hardware evaluation licence to test it on my board. But, during bitstream generation i get that : [Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted: sdi_yuv_to_video_rgb_0/resampler/U0 (v_cresample_0__v_cresample) If a new IP Core license was added, in order for the new license to be picked up, the current netlist needs to be updated by resetting and re-generating the IP output products before bitstream generation. I tried to reset/generate output products, but no effect. I attach screenshots of the IP interface, and report IP status. If someone could helps me... Thanks |
7个回答
@pgrangeray
使用该信息从以下答复记录中获取生成的IP中的许可证信息,并查看生成的IP是否实际选择了HW Eval许可证。 https://www.xilinx.com/support/answers/44033.html --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @pgrangeray Use the information to get the License info from the generated IP from the following Answer record and see if your generated IP is actually picking HW Eval license. https://www.xilinx.com/support/answers/44033.html --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz
所以,我得到: Proj_IP = v_cresample_0 license key = v_cresample@2013.03 以上来自于谷歌翻译 以下为原文 @syedz So, i get : Proj_IP = v_cresample_0 license key = v_cresample@2013.03 |
@pgrangeray
这提供了很多信息。 您可以运行以下TCL命令并在USED_LICENSE_KEYS下共享信息吗? report_property -all [get_ips v_cresample *] 如果它具有“design_linking”,则表示该工具在生成期间未选择此IP的HW Eval许可证。 如果重置输出产品后跟生成输出仍然给出相同的行为,那么我怀疑问题必须与您的许可证文件有关(它是否已过期或您在生成许可证文件时使用了错误的HostID) 你能共享HW Eval许可文件(.lic)和xinfo.txt文件吗? 从Vivado TCL控制台运行以下命令以生成xinfo.txt。 report_environment -file xinfo.txt 运行该命令后,只需键入“pwd”,这将显示生成xinfo.txt文件的路径。 您可以浏览到该路径并找到该文件。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @pgrangeray This doesn't give much info. Can you run the below TCL command and share the information under USED_LICENSE_KEYS? report_property -all [get_ips v_cresample*] If it has "design_linking" then it means that tool did not pick the HW Eval license for this IP during generation. If reset output products followed by generate outputs is still giving the same behaviour then I suspect the issue must be with your license file (either it got expired or you have used incorrect HostID when generating license file) Can you share the HW Eval license file (.lic) and xinfo.txt file? Run the following command from Vivado TCL console to generate xinfo.txt. report_environment -file xinfo.txt After running the command just type “pwd” this will show you the path where the xinfo.txt file is generated. You can browse to that path and find the file. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz
输出命令: report_property -all [get_ips v_cresample *]警告:[Vivado 12-3670]只应在表示此IP的文件对象上查询generate_synth_checkpoint属性。 使用get_files命令访问文件对象。警告:[Vivado 12-3672]只应在表示此IP的文件对象上查询is_managed属性。 使用get_files命令访问文件对象。属性类型只读ValueALLOWED_SIM_TYPES string * true rtlBOARD string trueCLASS string true ipCONFIG.ACLK_INTF.FREQ_HZ string false 148500000CONFIG.Component_Name string false v_cresample_0CONFIG.S_AXI_ACLK_INTF.FREQ_HZ string false 100000000CONFIG.active_cols string false 1920CONFIG.active_rows string false 1080CONFIG.chroma_parity string false oddCONFIG.convert_type string false 1CONFIG.field_parity string false oddCONFIG.has_axi4_lite string false falseCONFIG.has_debug string false falseCONFIG.has_intc_if string false falseCONFIG.interlaced string false falseCONFIG.m_axis_video_format string false 3CONFIG.max_cols string false 1920CONFIG.num_h_taps string false 2CONFIG.num_v_taps string false 0CONFIG.s_axis_video_data_width string false 8CONFIG.s_axis_video_format string false 2CORE_REVISION int true 13DELIVERED_TARGETS string * true cmodel testbench changelog simulation synthesis instantiation_templateDESIGN_TOOL_CONTEXTS string *真正的HDL IPI SysgenIPDEF串真xilinx.com:ip:v_cresample:4.0IP_CORE_CONTAINER串真正的C:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0.xcixIP_DIR串真正的C:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/ sources_1 / IP / v_cresample_0IP_FILE串真正的C:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0/v_cresample_0.xciIS_LOCKED布尔真0KNOWN_TARGETS串*真正cmodel测试平台的changelog模拟合成instantiation_templateNAME串真v_cresample_0PART串真xc7a50tfgg484-2REQUIRES_VIP布尔trueSCOPE串 trueSELECTED_SIM_MODEL string false rtlSTALE_TARGETS string * trueSUPPORTED_TARGETS string * true cmodel testbench changelog simulation synthesis instantiation_templateSUPPORTS_MODREF bool true 1SW_VERSION string true 2018.1UNSUPPORTED_SIMULATORS string * trueUPGRADE_RESULT string trueUPGRADE_VERSIONS string * trueUSED_LICENSE_KEYS string * true {{cmodel {v_cresample@2013.03 hardware_evaluation}} {testbench {v_cresample@2013.03 hardware_evaluation}} {changelog {v_cresample@2013.03 hardware_evaluation}} {simulation {v_cresample@2013.03 hardware_evaluation}} {synthesis {v_cresample @ 2013.03 hardware_evaluation}} {instantiation_template {v_cresample@2013.03 hardware_evaluation}}} USER_LOCKED bool false 0 许可证文件位于.zip中。 xinfo.txt 74 KB Xilinx.zip 1 KB 以上来自于谷歌翻译 以下为原文 @syedz Output of the command : report_property -all [get_ips v_cresample*] WARNING: [Vivado 12-3670] The generate_synth_checkpoint property should only be queried on the file object representing this IP. Use the get_files command to access file objects. WARNING: [Vivado 12-3672] The is_managed property should only be queried on the file object representing this IP. Use the get_files command to access file objects. Property Type Read-only Value ALLOWED_SIM_TYPES string* true rtl BOARD string true CLASS string true ip CONFIG.ACLK_INTF.FREQ_HZ string false 148500000 CONFIG.Component_Name string false v_cresample_0 CONFIG.S_AXI_ACLK_INTF.FREQ_HZ string false 100000000 CONFIG.active_cols string false 1920 CONFIG.active_rows string false 1080 CONFIG.chroma_parity string false odd CONFIG.convert_type string false 1 CONFIG.field_parity string false odd CONFIG.has_axi4_lite string false false CONFIG.has_debug string false false CONFIG.has_intc_if string false false CONFIG.interlaced string false false CONFIG.m_axis_video_format string false 3 CONFIG.max_cols string false 1920 CONFIG.num_h_taps string false 2 CONFIG.num_v_taps string false 0 CONFIG.s_axis_video_data_width string false 8 CONFIG.s_axis_video_format string false 2 CORE_REVISION int true 13 DELIVERED_TARGETS string* true cmodel testbench changelog simulation synthesis instantiation_template DESIGN_TOOL_CONTEXTS string* true HDL IPI Sysgen IPDEF string true xilinx.com:ip:v_cresample:4.0 IP_CORE_CONTAINER string true c:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0.xcix IP_DIR string true c:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0 IP_FILE string true c:/Projet_Vivado/project_Optsys_NB_50fps_multilayer/project_Optsys_NB_50fps_multilayer.srcs/sources_1/ip/v_cresample_0/v_cresample_0.xci IS_LOCKED bool true 0 KNOWN_TARGETS string* true cmodel testbench changelog simulation synthesis instantiation_template NAME string true v_cresample_0 PART string true xc7a50tfgg484-2 REQUIRES_VIP bool true SCOPE string true SELECTED_SIM_MODEL string false rtl STALE_TARGETS string* true SUPPORTED_TARGETS string* true cmodel testbench changelog simulation synthesis instantiation_template SUPPORTS_MODREF bool true 1 SW_VERSION string true 2018.1 UNSUPPORTED_SIMULATORS string* true UPGRADE_RESULT string true UPGRADE_VERSIONS string* true USED_LICENSE_KEYS string* true {{cmodel {v_cresample@2013.03 hardware_evaluation}} {testbench {v_cresample@2013.03 hardware_evaluation}} {changelog {v_cresample@2013.03 hardware_evaluation}} {simulation {v_cresample@2013.03 hardware_evaluation}} {synthesis {v_cresample@2013.03 hardware_evaluation}} {instantiation_template {v_cresample@2013.03 hardware_evaluation}}} USER_LOCKED bool false 0 Licence file is in the .zip. |
嗨@ pgrangeray,
浏览环境报告,您有硬件评估许可证,但它显示为主机ID不匹配。 因此,您需要根据您的计算机使用正确的主机ID重新托管此IP许可证。 有关它的更多信息,请查看https://www.xilinx.com/support/answers/36136.html 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @pgrangeray, Going through your environment report, you have hardware evaluation license but it is showing as host id mismatch. Hence, you need to rehost this IP's license with correct host id as per your machine. For more info on it please check https://www.xilinx.com/support/answers/36136.html Regards, hemangd |
你好@ hemangd
我删除了许可证,并生成了新的许可证。 现在,主机ID匹配! 但比特流再次失败。 重置输出和重新生成不能解决问题。 我附加了新的xinfo.txt文件。 xinfo.txt 73 KB 以上来自于谷歌翻译 以下为原文 Hi @hemangd I delete the licence, and generate a new licence. Now, Host Id matches! But bitstream generation fails again. Reset output and regenerate do not solve the problem. I attach the new xinfo.txt file. |
嗨@ pgrangeray,
使用此IP重新创建项目并检查。 如果它没有帮助,请再次发布您现在面临的错误。 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @pgrangeray, Re-create your project with this IP and check. If it does not help, post your error once again which you are facing now. Regards, hemangd |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 08:58 , Processed in 2.057901 second(s), Total 54, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1895
