电子发烧友论坛|
我已经下载并阅读了组件作者指南。(HTTP://wwwyCysP.COM/FIL/13736/下载)
它有一个美丽的句子: 注意,还可以从下拉菜单中选择“添加现有”,以选择要添加到组件中的现有符号文件。 这就是它所说的一切。对话框要求我知道在哪里保存要从中导入组件的库。大约一个小时的谷歌搜索没有结果。我钻进了程序文件-GT;Copress & Gt;PSoc Creator & Gt;4.1 & & PSocd Creator;& gt;PSoC & gt;内容-gt;CyCultStudio库,但是在那里没有一个库(对话框识别)。 我必须这样做,因为EMFLASH工作在我们的一个板上SD卡,但不是在另一个,其唯一的差异是PIN端口。不幸的是,该组件是完全不透明的,没有源代码的图书馆,客户要求的产品。不用担心,我总能找到一份新工作。 信号在100 MHz数字示波器上看起来是相同的。Heck,同一SD卡工作在我的电脑上,似乎在SD卡板持有人的工作板,但拒绝回应在另一个板。两者都有PSoC5LP器件。 我们怀疑有一些关于引脚选择,引脚的设置可能是重要的。所以我想编辑这个组件看看PIN以及它们是如何建立的。 事实上,我之前做过3.3岁以下,但在4.1岁以下,看起来要困难得多。 我不能把我的电脑从窗户扔出去,但它变成了一种严峻的诱惑。也许我可以移动到一个微芯片设备,但学习曲线将让我。 以上来自于百度翻译 以下为原文 I have downloaded and read the component author's guide. (http://www.cypress.com/file/137436/download ) It has a beautiful sentence in it: Note You can also select Add Existing from the pull-down menu to select an existing symbol file to add to the Component That is all it says. The dialog demands I know where you keep the library I want to import components from. About an hour of searching Google yielded nothing. I drilled down into the Program Files -> Cypress -> PSoc Creator -> 4.1 -> PSocd Creator -> psoc -> content -> CyComponentLibrary, but there is not a library there (that the dialog recognizes.) I am having to do this because emFile works on one of our boards with an SDCard, but not on another, whose only difference is pin port. Unfortunately, that component is totally opaque, there is no source code for the library, and customers are demanding the product. No worries, I can always find a new job. Signals look the same on a 100 mhz digital oscilloscope. Heck, the same SDCARD works on my computer, and appears to respond on that sd card board holder with the working board, but refuses to respond on another board. Both have psoc5lp devices in them. We are suspecting there is something about the pins chosen, setup of the pins may matter. So I want to edit the component to look at pins and how they were set up. I have actually done this under 3.3 before, but under 4.1, it appears to be much, much more difficult. I can't throw my computer through the window, but it is becoming a severe temptation. Maybe I can move to a microchip device, but the learning curve will get me. |
4个回答
Segger提供了EMFLASH组件库的源代码。
嵌入式文件系统——嵌入式专家系统 以上来自于百度翻译 以下为原文 Source code of Emfile component Library is provided by Segger. emFile - Embedded File System | SEGGER - The Embedded Experts |
你好,
我相信你正在寻找的是导入组件和查看引脚设置。 谢谢 Jobin燃气轮机 以上来自于百度翻译 以下为原文 Hi, I believe what you are looking is to import the component and see the pins settings. Thanks Jobin GT |
嗨,Ank, 我猜你不明白。PSoC Creator分量分为两部分。第一部分是符号,它是后面的信息的象征。这些信息包括引脚、用Verilog源代码编写的各种部件,以及(可能的)皮质ARM处理器的C源代码。这些信息隐藏在“组件”中,但是PSoC文档表明组件可以被编辑。过去我曾用PSoC Creator的以前版本做过这件事。但是,PSoC Creator 4.1的能力更难,我试图找出如何看待Verilog、PIN等组件。 在“EMFLASH”组件的情况下,它还具有第三方专有库,该库使用链接器加载第三方库,并在生成属性中设置该项目。我很清楚CyPress没有那个源代码。 我很清楚Segger拥有并已经隐藏了这个组件的源代码。我显然可以推断,图书馆的源代码不是塞浦路斯与Segger签署的许可协议的一部分。 我希望能够编辑组件,而不是查看库源代码。 我希望这些信息对你有帮助,Ank。 以上来自于百度翻译 以下为原文 Hi Ank, I guess you don't understand. The PSoC Creator component has two parts. The first part is the symbol, which is a façade for the information behind it. This information includes pins, various pieces written in verilog source code, and (possibly) C source code for the Cortex arm processor. This information is hidden inside the "component," but the PSoC documentation indicates that components can be edited. I have done that in the past with previous versions of PSoC Creator. However, that ability is more difficult with PSoC Creator 4.1, I am trying to find out how to look at a component verilog, pins, etc. In the case of the "emFile" component, it also has a third party, proprietary, library that is linked with the project using the linker loading a third party library, set in the Build properties. I am well aware that Cypress does not have that source code. I am well aware that Segger owns and has hidden the source code to this component. I can obviously infer that the library source code was not part of the licensing agreement that Cypress signed with Segger. I want to be able to edit the component, not look at the library source code. I hope this information helps you, Ank. |
谢谢你,Jobin! 那正是我要找的! 以上来自于百度翻译 以下为原文 Thank you Jobin! That was *exactly* what I was looking for! |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 22:35 , Processed in 0.728621 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4631
