电子发烧友论坛|
大家好,
某些开发板上可用的FMC连接器有哪些用途? 以上来自于谷歌翻译 以下为原文 Hi all, What are the uses of an FMC connector available on some development boards? |
5个回答
你好
FMC卡有助于使用相同的开发板开发各种应用程序特定的设计,并使用连接器仅使用该特定应用所需的不同子板 查看以下链接以获取更多信息 https://wwws.samtec.com/standards/xilinx.aspx http://www.fpgadeveloper.com/2011/06/fpga-mezzanine-card-fmc-game-changer.html http://solutions.inrevium.com/products/fmc/hpc/index.html 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi FMC cards help to develop various applications specific design with the same development board and just using an different daughter boards required for that specific application using the connectors Check below links for more info https://wwws.samtec.com/standards/xilinx.aspx http://www.fpgadeveloper.com/2011/06/fpga-mezzanine-card-fmc-game-changer.html http://solutions.inrevium.com/products/fmc/hpc/index.html Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. ---------------------------------------------------------------------------------------------View solution in original post |
你好
FMC卡有助于使用相同的开发板开发各种应用程序特定的设计,并使用连接器仅使用该特定应用所需的不同子板 查看以下链接以获取更多信息 https://wwws.samtec.com/standards/xilinx.aspx http://www.fpgadeveloper.com/2011/06/fpga-mezzanine-card-fmc-game-changer.html http://solutions.inrevium.com/products/fmc/hpc/index.html 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi FMC cards help to develop various applications specific design with the same development board and just using an different daughter boards required for that specific application using the connectors Check below links for more info https://wwws.samtec.com/standards/xilinx.aspx http://www.fpgadeveloper.com/2011/06/fpga-mezzanine-card-fmc-game-changer.html http://solutions.inrevium.com/products/fmc/hpc/index.html Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
您可以使用外部FMC板使用具有多种用途的相同电路板。
xilinx板是通用的,但有些机构需要特定的应用,他们可以将FMC板插入xilinx板。 FMC板通常需要混合信号应用检查此链接,以了解有关FMC板和支持的应用程序的详细信息https://www.xilinx.com/products/boards-and-kits/fmc-cards.html 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 You can use same board with multiple purpose using external FMC board . The xilinx board are generic but some body want specific application they can plug FMC board with xilinx boards . The FMC board in general required to mixed signal application check this link to know detail about FMC boards and supported applications https://www.xilinx.com/products/boards-and-kits/fmc-cards.htmlThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我想将8个迷你带状母26针连接器连接到FPGA板以及连接到FPGA的VHDCI连接器。
这是否与FMC连接器有链接? 以上来自于谷歌翻译 以下为原文 I want to connect 8 mini ribbon female 26 pins connectors to a FPGA board as well as a VHDCI connector to the FPGA. Does this have a link with FMC connectors? |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1198浏览 1评论
/9
GMT+8, 2025-12-14 04:38 , Processed in 0.893913 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4255
