电子发烧友论坛|
你好,
我们正在尝试用FX3+SPARTAN6开发环境,但是我们收到的数据有问题。我们遵循AN6997,实例0xA5* 1024运行良好。但是,如果我们发送随机数据,接收到的数据位错误。我们尝试了其他重复数据,0xFF*1024,0x37×1024等。然而,随机数据不是。 那么,问题是什么呢?你能帮助我们吗? 以上来自于百度翻译 以下为原文 Hello, We are trying to our development environment with FX3+Spartan6, but we got a problem with received data. We followed AN65974, and the example 0xa5 * 1024 worked well. But if we sent random data, the received data got bits errors. We tried other repeated data, 0xff * 1024, 0x37 * 1024, etc, they were worked. Yet, random data was not. So, what could the problem be? Can you help us? |
7个回答
你能分享你发送和接收数据的随机数据的截图吗?
还让我们知道你发送的数据在端点上的大小和你在端点上收到的数据的大小吗? 以上来自于百度翻译 以下为原文 Can you share the screen shot of random data that you have sent and received data? Also let us know the size of the data you have sent over OUT End point and size of data you requested to received on IN Endpoint? |
这是数据。它们都是1024字节。 下面的一个是在100MHz工作的结果之一。 第二个是在10MHz工作的结果。 以上来自于百度翻译 以下为原文 Here is the data. They were all 1024 Bytes. This following one is one of the results working at 100MHz. This second one is the result working at 10MHz. |
你能探测GPIF接口上的数据线并检查FPGA是否正确地循环回数据吗? 它给FPGA带来了什么,FPGA又在循环什么? 你也可以复制1024个数据包发送到批量缓冲区到本地缓冲区,并通过UART接口打印。为此,我们必须使用DMA手动通道, 并将DMA缓冲区复制到DMA生产者事件回调中的本地缓冲区(CYU-U3PYDMABCBOPRODIAL事件)。 对GPIF侧接收的缓冲区执行相同的操作,并将其打印到UART上。 这有助于理解FX3或FPGA在哪里出错。 以上来自于百度翻译 以下为原文 Can you probe the data lines over the GPIF Interface and check whether the FPGA is Looping back the data correctly? What it is send to FPGA and what FPGA is looped back? You can also do copying the 1024 packet that is send over BULK OUT EP to local buffer and print it over the UART Interface. For this, we have to use DMA manual channel, and copy the DMA Buffer to a local buffer in the DMA PRODUCER Event Call back (CY_U3P_DMA_CB_PROD_EVENT). Do the same for the buffer received on GPIF Side and print it over the UART. This helps in understanding where it is going wrong either in FX3 or FPGA. |
yahan52 发表于 2018-12-26 09:14 我们检查了程序,得到了这些数据。这次我们发送7字节的512字节数据。 我们发现FX3发送正确的数据直到最后1个块(4字节),然后发送第二个最后一个块。 然后FPGA环回数据丢失了前1个块(4字节),以及最后1块上的未知数据。 以上来自于百度翻译 以下为原文 We checked the procedures and got this data. We send 512Bytes data by 7 MHz this time. We found FX3 was sending correct data until the last 1 block(4Bytes), It sent the second last block instead. Then the FPGA loop-back data lost the first 1 block(4Bytes), and unknown data on the last 1 block. |
qwer35 发表于 2018-12-26 09:23 100兆赫的情况也一样吗? 你能分享FX3部分的原理图吗? 请检查您是否遵循了在AN70707应用程序注释中提供的硬件指南。 特别是,GPIF Part 以上来自于百度翻译 以下为原文 Is the same happening at 100 MHz too? Can you share the schematic of FX3 part? Please check whether you have followed Hard ware guidelines provided in the AN70707 App Note. Especially, GPIF Part |
我们遵循了AN6997的示意图。 并连接所有以下引脚(红色强调)与跳线 在100MHz下,接收到的数据在任意位置得到6~15比特的误差。 以上来自于百度翻译 以下为原文 We followed the schematic in AN65974 and connected all following pin(highlighted by red) with jumpers In 100MHz, the received data got 6-15 bit-error at random positions. |
我们还发现,在50MHz和60MHz的数据是正确的,而平均速度大约为15Mb/s。 以上来自于百度翻译 以下为原文 We also found that the data was correct at 50MHz and 60MHz, while the average speed is 15MB/s approximately.
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7255 浏览 0 评论
2482 浏览 1 评论
2176 浏览 1 评论
4037 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2082 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7750浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6308浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
752浏览 2评论
725浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8144浏览 2评论
/9
GMT+8, 2025-12-9 18:05 , Processed in 0.746860 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
382
